You may recall I was having troubles with the seal setting on the rear half-shaft. Pulled it and discovered the oil seal had been mangled when the bearing went in - new oil seal - bearing now properly seated (with a press) all is installed and I cannot for the life of me find out how tight to torque the nut holding the bearing on - anyone out there know?
thanks
JP
thanks
JP
