Quick Speedo Question
jjbunn
How does the trip-reset cable detach out of the back of a TR6 speedo? Twist and pull? Screw?
Thanks!
jjbunn
jjbunn
A photo would be most welcome :smile:
DNK
I hope this is what you need
NutmegCT
Man - talk about dedication. He races outside and takes the whole dash apart just to help a guy out. Gotta hand it to ya ...
T.
DNK
Takes ,nothing, I <span style='font-size: 26pt'>RIPPED</span> it out
jjbunn
jjbunn
Brilliant: many thanks!
2wrench
Love the Forum!!!! Wow!!! What service!!! What
dedication.
Rips it apart for a Fellow member.
Goooooo, DNK.
Brosky
Ever notice that there are many quick questions, but rarely ever, quick answers?
Don must have taken all of five minutes to get back to Julian. He's really dogging it on this one.
Great pic Don!! Worth a thousand words.
jjbunn
jjbunn
To detach just requires squeezing the plastic clips, and pulling. It was clear once I saw the photo.
Thanks everyone.
Brosky
I thought that someone mentioned once that there was a retaining clip hidden in there?
jjbunn
jjbunn
Well, if there is, then it's still in there /bcforum/images/%%GRAEMLIN_URL%%/blush.gif
hondo402000
I hope your not planning on using it again, you should have taken the unit apart, its got those springy plastic clips you must release from the inside, pulling and ripping will work but damage is likely just my imput cause I found out the hard way
jjbunn
jjbunn
I will be taking it apart. I prefer to remove all cables from the back of an instrument before taking it apart ....
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T MGB Quick question about something that don't really matter just want to know. MG 9
dougie A Quick Trip Around Oulton Park.... Austin Healey 3
S Wedge tr7/8 quick release steering wheel Triumph 0
Jim_Stevens TR2/3/3A Quick measurement needed Triumph 4
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
P TR6 Quick starting Triumph 2
S MGB 1980 MGB quick question MG 2
2billydavies TR2/3/3A Just a quick thanks to everyone who helped with my questions Triumph 7
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
judow Can't post except in quick reply and other issues FORUM Navigation Questions 0
Willie_P TR4/4A Quick HELP - TR4 fender beading.... Triumph 3
H quick insulation paint color quesrion Austin Healey 7
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
S TR6 Quick TR6 alternator question Triumph 6
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
M Quick tachometer wiring question on a '65 Spridgets 10
Jim_Gruber Quick Engine Install for Bugsy II Spridgets 22
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
Willie_P Quick question: rear diff TR 3/4 Triumph 6
Willie_P Help: quick hub torque questions Triumph 3
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
aeronca65t MGB Quick MGB motor swap MG 3
MCNX_BFF Quick catch-up and trailer question Triumph 8
RJS Radiator Fan Bolts - need quick help Triumph 4
skelly Quick question from a newbie Spridgets 10
B Smelling like fuel and oil after a quick drive? Austin Healey 29
PatGalvin Captive nuts?? quick question Triumph 7
abarth69 quick help needed Spridgets 3
JPSmit Quick Spark plug question Spridgets 10
Coyote1 Need a quick measurement Triumph 7
T TR4/4A Two quick OD TR4a wiring questions Triumph 7
regularman Quick, right now go to ESPN Spridgets 2
glemon Quick Easy Removeable Cupholder Triumph 4
Randy Forbes Quick's trip to the Morgan Motor Co., LTD... Austin Healey 4
J Details, Details. Quick questions. Spridgets 11
PATR8 a quick look at the Pittsburgh Craigslist Triumph 1
drooartz MGB That was quick: MGB heading to my garage MG 24
Sarastro Quick dumb transmission question Spridgets 9
S A quick introduction Spridgets 21
T Quick fuel pump question - mounting angle MG 3
S Quick Release Steering wheel hub Triumph 1
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
M Spitfire Quick fix for spitfire sag Triumph 7
bigjones HS4 - quick question MG 6
QuickSilver A Quick Return To The Fold MG 11
