TR6 Quick TR6 alternator question
sammyb
I got all ready to finally fire up the TR6 after the whole head R+R saga (adjusted valves today.) Huge squeal from the alternator. It was actually the alternator cooling fan fins rubbing against the housing. The fan was actually spinning on the shaft, due to sitting on the shaft past the keyway. Isn't it supposed to be on the shaft keyway? Is there supposed to be a washer/shaft lock to keep it on the key and away from the housing? When the alternator was off, I don't recall taking off the fan -- just the pulley. Of course, I was using the alternator nut to turn the engine (plugs out) to adjust the valves, so I wonder if I bent the fan?
If anyone has a good set of photos of the alternator pulled apart and where the fan is supposed to sit, it would be helpful. I'm breaking for a late lunch to catch my wits.
As always, thanks y'all.
Sam,
I believe it is keyed. I have some more pictures (not exactly what you want) here: https://www.tidentenn.com/CC78xxxLO/41 (12-16-2009 (ALTERNATOR))/index.html
One of the other pictures shows the key slot in the shaft. Hope it helps. Tim.
Yes -- I know it is keyed, but the fan slips all the way down past the end of the key on the shaft. The key only goes a few inches, and then there's an inch or two that's non-keyed.
Should be a spacer in there, between the fan & inner bearing race. When you tighten up the nut, it clamps the pulley, fan and spacer against the bearing race (which in turn butts against a shoulder on the shaft).
Sorry I don't have a photo handy.
The spacer isn't there! That's my issue. Thanks Randall....I'll have to MacGyver something.
So I pulled off the alternator and since there was no spacer, I basically made one by cutting down a rubber spark plug boot. Seems to fit and work fine. Since I might just need to replace the alt at some point in the future (when I tried to open it, one of the long screws broke, so even though the bearings make no noise and don't wobble, it's an old one), I'm not going to fret too much about the MacGyvering.
I was able to take a moment to see if I could finally start the car. Gave it a shot of starting fluid and it was coughing and trying to start -- just didn't totally catch. Oil pressure went up to around 60ish. Good signs!
I'm out of time for the weekend, so on Monday or Tuesday I'll see if the fuel pump is pushing fuel. At least she wants to run!
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
cmacmillan TR6 Quick question on Haynes for TR6... Triumph 3
C TR6 I need a little help....quick measurment on a TR6 Triumph 2
M TR6 TR4 - TR6 "Quick Rack" - o-pinions? Triumph 2
S TR6 TR6 rear brakes--quick question Triumph 3
V TR6 Quick question... Picture [TR6] Triumph 8
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T MGB Quick question about something that don't really matter just want to know. MG 9
dougie A Quick Trip Around Oulton Park.... Austin Healey 3
S Wedge tr7/8 quick release steering wheel Triumph 0
Jim_Stevens TR2/3/3A Quick measurement needed Triumph 4
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
P TR6 Quick starting Triumph 2
S MGB 1980 MGB quick question MG 2
2billydavies TR2/3/3A Just a quick thanks to everyone who helped with my questions Triumph 7
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
judow Can't post except in quick reply and other issues FORUM Navigation Questions 0
Willie_P TR4/4A Quick HELP - TR4 fender beading.... Triumph 3
H quick insulation paint color quesrion Austin Healey 7
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
M Quick tachometer wiring question on a '65 Spridgets 10
Jim_Gruber Quick Engine Install for Bugsy II Spridgets 22
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
Willie_P Quick question: rear diff TR 3/4 Triumph 6
Willie_P Help: quick hub torque questions Triumph 3
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
aeronca65t MGB Quick MGB motor swap MG 3
MCNX_BFF Quick catch-up and trailer question Triumph 8
RJS Radiator Fan Bolts - need quick help Triumph 4
skelly Quick question from a newbie Spridgets 10
B Smelling like fuel and oil after a quick drive? Austin Healey 29
PatGalvin Captive nuts?? quick question Triumph 7
abarth69 quick help needed Spridgets 3
JPSmit Quick Spark plug question Spridgets 10
Coyote1 Need a quick measurement Triumph 7
T TR4/4A Two quick OD TR4a wiring questions Triumph 7
regularman Quick, right now go to ESPN Spridgets 2
glemon Quick Easy Removeable Cupholder Triumph 4
Randy Forbes Quick's trip to the Morgan Motor Co., LTD... Austin Healey 4
J Details, Details. Quick questions. Spridgets 11
PATR8 a quick look at the Pittsburgh Craigslist Triumph 1
drooartz MGB That was quick: MGB heading to my garage MG 24
Sarastro Quick dumb transmission question Spridgets 9
S A quick introduction Spridgets 21
T Quick fuel pump question - mounting angle MG 3
S Quick Release Steering wheel hub Triumph 1
