Help: quick hub torque questions
Willie_P
hi-
can someone real-quick provide me with the proper torque values (I was looking in the workshop manual and did not immediately see these):
+wire wheel spline-drive studs to hub face (front and rear, the actual studs (four per wheel, I think) and special nuts)
+the rear hub/bearing carrier to the axle housing flange(6 bolts per side that thread directly into the rear hub)
+the propshaft flanges where they mount to the tail-end of the gearbox and to the rear pinion flange (four bolts per flange).
thanks! -wes
For the splined adapters, there is a service note that says to tighten them to 65 ftlb, then drive approx 10 miles and check again.
Bearing caps 34-36 ftlb
I don't know of a spec for the flanges, but the special bolts seem pretty hard, so 'standard' torque would be somewhere between 40 ftlb (Grade 5) and 60 ftlb (Grade 8). It's really tough to get in there with a torque wrench anyway, so I just tighten them as tight as I can with the box-end wrenches I use.
FWIW, I also use 'Stover' nuts on the flanges, instead of the factory Nylocs. I found that even brand new Nylocs would work loose in a few thousand miles.
Worth a try, I guess, but seems like a lot of extra work. I just bought a box of "oval lock with conical top" nuts from MMC , which should be a lifetime supply.
Willie_P TR4/4A Quick HELP - TR4 fender beading.... Triumph 3
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
RJS Radiator Fan Bolts - need quick help Triumph 4
abarth69 quick help needed Spridgets 3
N Need some diagnosis help quick! Triumph 12
crya QUICK-Need Help w/ Interior Color Combos Austin Healey 6
S What is this car? Quick help needed. Austin Healey 31
motofiaccone U-Bolts <Quick Help> Spridgets 4
C TR6 I need a little help....quick measurment on a TR6 Triumph 2
10musketeer Quick help with grease cleanup Spridgets 8
G TR2/3/3A Quick Help - taking the cover off a TR3 tranny Triumph 3
jaybird HELP! QUICK!!! MG 4
G QUICK HELP...... Triumph 3
tr6web TR6 TR6 Manifold gasket help Triumph 0
D TR2/3/3A Please help w this tuneup Triumph 19
D Help with what 4 numbers on MGC VIN mean MG 10
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
