Series II gear lube question
LD-Ordie
Early transmissions should be running G4 type gear lube as I have read, common G5 lube is bad for anything brass or yellow. How critical is this? G4 is getting hard to find and is $$$$. What is everybody using in theirs? Not trying to create another oil thread, but not a lot of info on this out there. Thanks
PAUL161
I use Red Line 90W. PJ
LarryK
I use G4 in all my older Rovers. G5 is used in higher pressure like limited slip units. I have used G5 in the Discos with no problems. You think G5 is $$$, Try the synthetics for newer Rovers. You can get customer support at Rovers North and Alantic British.
LD-Ordie
LD-Ordie
I do like Red Line products, was just trying to get away from fluids that are $24. a quart. I own 3 vehicles that requires a GL4. A 68 Dart, a 59 Triumph TR3A and my 64 IIA. It has a leak that cannot be repaired without pulling the gear box, something I have been trying to avoid. It leaks about a quart a year. So my routine for the last 15+ years is to put it up on my lift, check all the reservoirs, oil change, lube and a general PM. Have been using AmsOil, which is good oil for $17. a quart. But just discovered this stuff. Is advertised on Amazon for $16. a quart, but also is available in a 5 gal jug for $7. a quart with tax. Going to give it a shot. I don't mind dealing with 5 gal. jugs as it is how I buy my Rotella T6 oil, which I use in all my vehicles. GL5 is used in everything that does not have anything yellow.
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
B B series distributor drive gear. MG 1
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
S M Series Bonnet Striker Pin failures TVR 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
G original radio 1961 e series jaguar Jaguar 3
Y M Series indicator lens TVR 3
Q Series 1 E Type Clutch Jaguar 2
F 1965 Humber Super Snipe Series Va Other British Cars 5
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
David Townsend T-Series MG Midget TC Series Limited Edition Illustrations MG 1
J TR4/4A TR4 Series Vehicle numbers Triumph 1
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
P XKE series 1 FHC windshield installation ?? Jaguar 4
