1971 Series I XJ6 parked for 12 years - fuel pump problem
twas_brillig
Helping a friend with the above. it was driven into the garage 12 years ago, fuel stabilizer added, and parked. We've drained passenger side fuel tank and there's 12 volts to the pump but no pumping. I can blow through the fuel inlet hose to the outlet. When voltage is applied, there is a 'gulp' type sound and when the voltage is disconnected, a small quantity of gasoline comes out the outlet - as if the diaphragm sucked in when power applied and pushed out when it was switched off. Driver's side pump also is not pumping and also has voltage but we haven't done any disassembly. Searching 'fuel pump' on the Forum was interesting but no luck. Thanks.
T
twas_brillig
we're thinking it's an issue with the electrical points at the top of the pump. Will investigate tomorrow and advise.
T
twas_brillig
Tried tapping (gently) to free up the ignition components and pump works.
Steve
Platinum
It could be that the diaphragm in each pump has perished. I believe that the fuel pump for the Triumph TR6 is a direct replacement, so that would be worth checking out.
MikeP
One other thing to keep in mind if the plan is to start driving it, the gaskets and seals in the engine and drive train may start to leak after a bit. when they don't get regular lubrication and have a chance to dry out in many cases they don't really handle rewetting well. And brakes can start to leak, particularly if they have gone dry.
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
T 1971 Fuse Box and Wiring Triumph 7
D TR6 1971 TR6 carbon canister Triumph 1
C For Sale 1971 TR6 Triumph Classifieds 0
C For Sale 1971 TR-6 For Sale Triumph Classifieds 3
C 1971 Citroen DS-21 Other Cars 13
S For Sale Aston Martin DB6 Factory Parts Manual on CD/ROM – 1965 - 1971 Models. Other British Classifieds 0
S For Sale Aston Martin DB6 Factory Workshop Manual on CD/ROM – 1965 - 1971 Models. Other British Classifieds 0
P For Sale 1971 TR6 for sale Triumph Classifieds 21
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
J For Sale 1971 tr6 Triumph Classifieds 0
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
A TR6 Lettering on 1971 dashboard Triumph 1
S MGB First potential project: 1971 MGB MG 17
B TR6 WTB: Side marker socket 1971 TR6 Triumph 2
B TR6 1971 clutch and rear oil seal Triumph 2
J MGB Length of MGB oil stick for 1971 MG 1
NutmegCT 1971 Mercedes-Benz 250 Spotted 1
P TR6 1971 TR6 compression Triumph 2
ShawnC_at_Moss MGA New - Plastic Fan for MGA & MGB to 1971 MG 10
zedvictor1 Spitfire 1971 MkIV Spitfire Triumph 3
O TR6 1971 TR6 Starter Help Triumph 1
O TR6 1971 TR6 Ignition Switch Swap Triumph 1
LBCs_since_1988 1971 Norton Commando Awoken After 30+ Years! British Motorbikes 4
mikecyc72usa MGB 1971 MGB Steering column cowl MG 4
B MGB 1971 MGB Wing or Fender removal. MG 2
N MGB-GT 1971 MGB Rear Shock mounting bolt length MG 0
T Just curious - 1971 Jag XKE 6 cyl value Jaguar 13
G MGB 1971 MGB door mirror MG 8
C REALLY fast British race car [circa 1971] Racing 0
G MGB My 1971 MGB horn MG 3
W MGB-GT 1971 MGB GT Won't Start MG 11
G MGB 1971 MGB...The Project begins! MG 24
69mgbgt Spitfire 1971 Spitfire headlamp switch Triumph 14
69MGC MGB 1971 MGB Custom Rebuild MG 34
Cookie 1971 Austin Healey Sprite eek - crunching gears! Austin Healey 3
D Spitfire 1971 Spitfire rear axle - Help! Triumph 3
D Spitfire Spitfire seats [1971] Triumph 8
NASpecMGB WTB Midget/Sprite orig shift knob, 1971 or earlier Spridgets 2
S Raising the height ona 1971 B...... MG 2
G Spitfire 1971-80 Spitfire owner's might be interested. Triumph 1
AngliaGT 1971 Honda 600 - $100 Other Cars 10
T 1971 midget???? Spridgets 7
beaulieu 1971 Lotus . Vin numbers / model numbers ? Lotus 24
B TR6 1971 TR6 won't idle. Triumph 35
bcliff GT6 1971 GT6 on craigslist Triumph 20
S 1971 Seven Lotus 13
Morris Spitfire 1971 Spit for Sale in Texas Triumph 3
AngliaGT Spitfire 1971 Spitfire - $1500 Triumph 0
vping RWA Midget a 1971? Spridgets 23
