HS vs HD series carbs
steveg
Enquiring minds want to know:
Why are HD series carbs so much more expensive than HS series? > $1000 more for the replacements.
HDs are used on Jaguars, Aston-Martins, RRs, Rovers and most later Healeys. HSs are used for the most part on cheaper cars: Triumphs, Volvos, MGs - (also BJ7s but never mind).
HSs would appear to be more complicated with all their washers and seals.
The relationship between the needle and the jet would appear to be the same, therefore one would think the horsepower produced would be the same.
This I believe gets into the arcane knowledge of the ancients, about which we can only speculate.
John Turney
Probably for the same reason grade 5 fine thread bolts are more expensive than grade 8 fine thread bolts. Or why propane is cheaper in remote areas than in suburban areas.
re: "Why are HD series carbs so much more expensive than HS series?"
To me, the HS is more complex and parts-intensive. I have cars with both; IMO the diaphragm jet on the Ds is probably more durable--and cheaper--since the seals on the Ses can dry and crack.
It may be an 'SU' thing: older costs more. The old SU pump used on early 6-cyl cars--with the big 'box' valve section--cost 3X the later ones (but the earlier 4-cyl pump, which could probably power a 6-cyl just fine, is less as well).
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
J XKE series II S/Z carbs hot start woes Jaguar 1
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
S M Series Bonnet Striker Pin failures TVR 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
G original radio 1961 e series jaguar Jaguar 3
Y M Series indicator lens TVR 3
Q Series 1 E Type Clutch Jaguar 2
F 1965 Humber Super Snipe Series Va Other British Cars 5
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
David Townsend T-Series MG Midget TC Series Limited Edition Illustrations MG 1
J TR4/4A TR4 Series Vehicle numbers Triumph 1
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
