TR6 Ignition Switch Question
SherpaPilot
Greetings to all my Triumph friends. After a little less than a year, I have finally installed my freshly rebuilt engine into my 72 TR6. All the subsystems seemed to go back on without problem with one little exception, my ignition switch. During the engine rebuild, I repainted my empty engine bay and of course had to reinstall all the wiring etc. It seems that my ignition switch now turns the engine over nicely but during the engine's rotation (during the start) no power is being sent to the coil. After the spring-loaded switch return to the "run" position, it then that the engine starts and all is normal. I hope this makes sense to someone. I'm sure I have missed a connection somewhere along the way but can't seem to figure this one out. I plan on going through the wiring diagrams tonight but thought someone may have a quick answer for me. As usual, thanks for any input. Don
bobhustead
Check the wiring diagram. There should be a wire going straight to the coil from the solenoid when it is engaged. Otherwise the starter draw parasitizes all the juice.
Bob
SherpaPilot
SherpaPilot
Hey Bob, Thanks for the response. My wiring chart shows a white wire from the fuse block going to the + side of the coil. The - side of the coil also has a white wire going directly to the spade on the distributor. I'm not showing any direct connection to the starter or alternator. I plan on tracing each wire for connunitity to assure they are correct. Your comment concerning the starter drawing all the current makes perfect sense but I do not see any current protection offered to the coil during the start sequence. I'll keep plugging away at this. Thanks again for your help. Don
poolboy
The schematic has it right, power from the ignition switch to the white wire side of the fuse for the green wire circuits and from that white wire side of the fuse to the positive terminal of the coil
In other words the coil gets 12 volts when the ignition key is in the START and in the ON/Run position.same as everything on the green wire side of that fuse.
If you have that wire from the fuse block to the coil, but no start when you twist the key to START maybe the problem is at the ignition switch
bobhustead
I just looked at the diagram and was going to posit a problem in the ig switch, too. But it looks like the white that powers the ig switch is in constant unswitched connection to the white that goes to the fuse box and thence to the coil. It appears there is no shunt like I suggested and power supply to the coil should be the same whether the switch is energizing the white/red or not. Makes no obvious sense to me, but Ken almost has to be right on this and the problem is the ig switch.
Bob
bobhustead
Just for the fun of it (fun not my first choice of words), try a supplemental jumper wire from battery pos direct to coil in and see if it starts during cranking instead of just when you let off the sprung ig switch connection.
Bob
bobhustead
In the feed to the ignition switch, there is a device (dunno what it is) shown on the diagram that has brown/yellow going in and white coming out. Possible fault in that device that keeps sufficient current from coming into the circuit to properly power white and white/red simultaneously?
Bob
SherpaPilot
SherpaPilot
Bob, Ken, Thanks for your expert help on this. I'll try that jumper wire from battery over to coil. A new ignition switch is probably a good idea. I have been reading wiring diagrams every chance I get and it is driving me crazy. Now I know why I'm not an electrical engineer. Thanks again, guys.
poolboy
Assuming the green wire components,such as the fan motor and windshield wipers work when you turn th ignition key to ON you should make that jumper to the coil from the white wire side of the fuse that protects the green wire circuit...otherwise if you directly use the battery, the coil will always be fed voltage even when the ignition key is OFF and when you want to stop the engine the only way to do it will be to remove the jumper from the battery.....AND if you do decide to use a direct connection to the battery, make sure the connection to the battery is the last to hook up and the first to disconnect....less sparking like that.....but go to the white wire side..that's the way to do it.
SherpaPilot
SherpaPilot
Bob, Yes, I knew what you were suggesting with the temporary jumper. I will get back to trouble-shooting this problem sometime today. I plan on doing a complete grounding check. I'm hoping I don't need to get into that ignition switch replacement. I know it is quite an involved job. But I'll do whatever it takes.
SherpaPilot
SherpaPilot
You guys will not believe this but, problem solved. I spent the day checking out grounding mounts; Nothing helped. I decided to bite the bullet and order up a new ignition switch but before I did, I pulled an old spare coil from my parts inventory and swapped it out with the existing coil. All of a sudden everything worked like it should. Who would have guessed a coil would fail like that? As far as I'm concerned, all is normal once again. Thanks once again to all of you guys who suggested ideas to look into, yout help is appreciated. Don
bobhustead
I guess I can see how current deprivation by the starter load might be the cause, but it would be great if one of our EEs could explain it. I would NEVER have guessed the coil.
Bob
longbridgehealey New Bugeye ignition switch question Spridgets 10
T TR4/4A TR4A ignition switch question Triumph 19
T TR4/4A TR4a ignition switch question Triumph 5
G ignition key/lock switch question Spridgets 0
Monark192 Ignition Switch / Steering Lock Removal Question Spridgets 1
T Question on ignition switch wiring Triumph 10
R Bugeye ignition switch Spridgets 2
R Wanted Bugeye ignition switch Spridgets Classified 2
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
P TR2/3/3A ignition switch smoking Triumph 12
C TR6 Ignition Switch for 1972 TR6 Triumph 1
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
longbridgehealey Bugeye ignition switch Spridgets 4
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
L TR6 1974 Tr6 ignition switch Triumph 3
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
A bugeye ignition switch Spridgets 2
A Bugeye ignition switch Austin Healey 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
S TR4/4A Ignition switch key position Triumph 2
J ignition switch, On but no starter at all times British Motor Corp 2
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
S BJ8 Ignition switch? Austin Healey 7
AngliaGT Ignition switch/Wiring Diagrahm..... Spridgets 0
AngliaGT Midget MKIII Ignition Switch Spridgets 0
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
rjc157 ignition switch Austin Healey 5
RedTR3 TR2/3/3A Ignition Switch Triumph 4
Gliderman8 TR6 Installing new ignition switch Triumph 7
RickB I was wrong. Again. Not ignition switch! Spridgets 16
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
G T-Series Ignition switch MG 10
B ignition switch Spridgets 5
M TR4/4A TR4A Ignition Switch Circuit Triumph 3
G T-Series Tachometer and ignition switch MG 16
T Ignition switch Triumph 6
D T-Series Access to ignition switch '68 MGB MG 9
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
