TR4/4A Ignition switch key position
shoopal
I am assembling the plinth that holds from left to right panel light rheostat, windscreen washer pump,wiper switch,ignition switch and choke cable.
The plinth hole has a cutout that only allows the switch to go in one way. However this position has the key hole upside down, with the key flat on the bottom.
Is this normal?
Al Shoop
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
BugeyeNJ58 Ignition Switch and key Cylinder comes apart! Spridgets 0
B T-Series Ignition key switch help ! MG 7
angelfj1 TR2/3/3A TR3A Ignition Switch - new lock/key Triumph 5
G ignition key/lock switch question Spridgets 0
G Removing ignition key/lock switch? Spridgets 5
R Bugeye ignition switch Spridgets 2
R Wanted Bugeye ignition switch Spridgets Classified 2
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
P TR2/3/3A ignition switch smoking Triumph 12
C TR6 Ignition Switch for 1972 TR6 Triumph 1
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
longbridgehealey Bugeye ignition switch Spridgets 4
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
L TR6 1974 Tr6 ignition switch Triumph 3
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
A bugeye ignition switch Spridgets 2
A Bugeye ignition switch Austin Healey 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
J ignition switch, On but no starter at all times British Motor Corp 2
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
S BJ8 Ignition switch? Austin Healey 7
AngliaGT Ignition switch/Wiring Diagrahm..... Spridgets 0
AngliaGT Midget MKIII Ignition Switch Spridgets 0
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
rjc157 ignition switch Austin Healey 5
RedTR3 TR2/3/3A Ignition Switch Triumph 4
Gliderman8 TR6 Installing new ignition switch Triumph 7
RickB I was wrong. Again. Not ignition switch! Spridgets 16
longbridgehealey New Bugeye ignition switch question Spridgets 10
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
G T-Series Ignition switch MG 10
B ignition switch Spridgets 5
M TR4/4A TR4A Ignition Switch Circuit Triumph 3
G T-Series Tachometer and ignition switch MG 16
T Ignition switch Triumph 6
D T-Series Access to ignition switch '68 MGB MG 9
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
