Bugeye light-ignition switch
Rut
Can anyone tell me how to disassemble and restore my combo switch? I've pressed every button and hidden hole I can see, but no joy.
Thanks, Rut
AN5Sprite
I've done it, but I can't recall exactly how I did it. :( I think there are tabs that need to be unbent. I also remember a tiny little ball and spring. Sorry, I'd have to go find one downstairs and look at it to remember. Rut, I'll do that if nobody else chimes in.
smaceng
Did you get the knob off? Press in the pin in the side of the knob, and that releases it to pull off.
what else?
Scott
Rut
Rut
Scott,
ive tried pushing the pin on the knob in and the knob won't budge. There's enough friction between the lock and the knob to cause them to turn in unison and I would like to clean it up.
Thanks, Rut
Whitephrog
Rut
I've had experience with two. The first I pushed the pin on the side in a slide the knob off without any problem. The second I all but destroyed the switch getting the knob off. The knob was absolutely frozen to the switch. In that case I had to break it into pieces. Didn't have a Dramel at the time. If I had I would have carefully cut it off.
jjscott
The knob on my switch wouldn't come off either. My knob is a bit crooked, as if it was forced on at one time. No amount of pulling or levering would move it. The switch can still be disassembled; mine needed a new lock tumbler because the key was missing. The new tumbler (Moss) went in OK, but it is slightly different in length. The only way I can get the key out is to hold the Knob forward while pulling on the key.
Jim
smaceng
Am I the one who said to push the pin in to remove the knob? Yes I think it was, no, I know it was!
I couldn't get the knob off the original switch either......Yes I tried to push the pin in, but no work-o.
I ended up cutting the knob off with a small grinder and buying a new knob!
Scott in CA
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
longbridgehealey Bugeye ignition and light switch Spridgets 9
I Bugeye ignition light still on- help please Spridgets 35
I Bugeye dash light problems Spridgets 9
D Start Bugeye with KEY only - OR - KEY plus light switch on S or H? Spridgets 4
P BUGEYE PANEL LIGHT SWITCH Spridgets 10
I Bugeye turn indicator light help please Spridgets 18
J Bugeye license plate light plinth Spridgets 10
I Bugeye turn light help Spridgets 1
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
