MGB 1980 mgb no power from ignition switch
HelpingTRresto
Hi all, need help with electrics. some one had reversed battery polarity. what got fried. new battery installed but positive terminal gets warm like a short or back feed. i put volt meter between post and cable with cable off of battery and get 12.5 volts with everything off like something is draining battery. there is no power coming from ignition switch when turned on. no dash lights, will not crank over. Thank you for your help.
Platinum
Not certain anything would melt and cause a dead short just from swapping polarity. Something else is going on IMHO. The brown wire at ignition switch is supposed to be +12V, not sure of source on a 1980, the older (pre-'68) ones got battery voltage from the solenoid, IIRC.
Try the diagrams on Advance Auto Wire for good info. Sounds like you've a mess on your hands, good luck!
Grantura_MKI
Later cars may have a starter relay and or fuse inline. As doc advises, consult a good diagram to trace what sort of electrical equipment you car has.
YakkoWarner
If the + terminal on your battery is getting warm something is pulling quite a bit of current (like wiring-harness damaging amounts). What I always do when hunting down suspect wiring (or testing wiring I have not examined fully myself) is use a hand-made current limiter. A standard sealed-beam headlight works well - put it in series with the + of the battery so even if you get a dead short, the worst that can happen is the light comes on full strength. If the light is off or very dim, there is only a small amount of current flowing. Using a simple rig like this, its easier to find stray current leaks by disconnecting various things until the light goes off.
My first suspicion is reversed polarity could have damaged the regulator inside the alternator (which is connected directly to the battery and is unfused). I would immediately unplug the connector at the back of the alternator. If you use a lamp as a current limiter, the light would go off when you unplug the alternator if that is the source of the drain.
I've been using that kind of a rig to test the wiring in the car I'm working on now since I wasn't sure what had been damaged by the previous owners. Its a lot less stressful testing unknown circuits when you know the worst that can happen is the headlight bulb comes on, and you'll never draw enough current to melt a wire or start a fire.
Platinum
I've always just used a 12V test light ( Snap-On, yes) for quick diagnosis. If it gets more serious, isolating all harness wires and a VOM to check each for crossover, continuity or inappropriate ground.
Had a look at the wiring diagram, Yakko has a good point. Pull the alternator plug and see if the draw disappears. But the brown wire at the ignition switch should be 'hot' regardless. Sounds like that's not the case unless the switch is faulty.
Platinum
The test light I suggested is fitted with an internal volt meter as well as the bulb.
Very classy! Mine is the Ancient "vintage" variety... CT4D. :giggle:
Platinum
I just was making do with whatever the heck I had laying around - a couple chunks of wire and an old truck headlight.
Same principle (and a lot less money)! Back in my salad days I soldered a couple wires to a 12V single filament taillight bulb.
H
HelpingTRresto
Thanks for all your help. I disconnected the altinator, no change, still drain on battery. my friend told me that before the electrics died the red light on dash glowed bright, that probably started happening when the battery was reversed. Am I correct that this car 1980 is neg earth? even though ground cable is red? I checked volts to main relay on inner fender toward front of car by the fuse block. Brown wire 12v with ign switch off. switch on volts 4.9, pos post got warm again. Thanks for input.
Platinum
Some random thoughts: Ignition light on with engine running (meaning the alternator is being spun) usually means the regulator or the alternator brushes are defective. And yes, the 1980 MGB is negative earth. Have you copied the wiring diagram on the Advance auto wire site? With your test light in between positive battery terminal and cable, you will have to disconnect things one-at-a-time until the light goes out. I'd start with the ignition switch feed (brown wire). Leave the alternator plug disconnected, pull the fuse in the fusebox that has brown wires into it. That takes out (purple) horn, seatbelt module (these have been problematic in the past) and cigar lighter. When the headlight goes out you've found the offending circuit, not necessarily the root cause.
All the brown wiring should be +12V regardless of the ignition switch position. Relays are generally polarity insensitive, solid state ones being an exception.
EDIT: Pulling fuses will also indicate circuit, but not which component is the problem.
Page 33:
Advance Auto-Wire
Platinum
Some folks have found it useful to have the appropriate diagram printed large and laminated by a place like Office Depot or a print or sign shop.
H
HelpingTRresto
Hi folks. Good news, all is well. alternator had to be rebuilt and new regulator. found a small ground in positive cable where it makes a bend under the body where it exits the battery box. also positive cable had a aftermarket battery clamp installed that had rusted and corroded where it connects to cable. replaced it and cleaned cable and post. installed new starter relay. Success! Thanks to all for your help. Cheers, Jim.
LarryK
Friend of mine did it in his Jag. Ruined voltage regulator, generator and wiper. Glad you found it. I got burnt on the wiper motor is how I found it.
Platinum
We've found electrical issues that boggle the mind. Pop-rivets thru a harness, tail lights went bizzaro. Ground straps corroded and the throttle cables melted, just to mention a couple.
LarryK
Yep, Doc, find all sorts in owner fixed and repaired cars.
Russ80MGB MGB 1980 MGB - No power MG 16
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
A MGB 1980 MGB MG 3
P MGB 1980 MGB carb and oil questions MG 3
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
C MGB 1980 MGB Roadster Tyres UK MG 0
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
M For Sale 1980 MGB for Sale MG Classifieds 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
kyreb1862 MGB 1980 MGB Timing Issue MG 5
Tinkerman MGB 1980 MGB wiring diagram help MG 6
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
Hoosier MGB 1980 MGB Suspension Issue MG 3
M MGB My 1980 MGB [Need some help please!] MG 28
Hoosier MGB 1980 MGB Trunk Lid MG 2
Hoosier MGB 1980 MGB Tail Light Chrome Trim MG 10
M MGB 1980 MGB LE or not?? MG 6
N MGB Question about ignition wiring unique to 1980 MGB MG 15
T MGB 1980 MGB 1800 Motor Color MG 6
D MGB 1980 MGB Roadster . . . Restoration Progress MG 32
K MGB 1980 MGB Seat Colours? MG 2
C MGB Console tunnel - 1977 - 1980 MGB MG 5
JamesWilson MGB-GT New 1980 MGB GT for sale.... MG 9
P MGB 1980 mgb fuel pump MG 3
C MGB looking for 1980 MGB limited edition informaton MG 13
M MGB WILL A 1973 MGB STEERING WHEEL FIT ON A 1980 MGB MG 0
M MGB Shakes at about 3000 RPM 1980 MGB MG 5
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
I MGB 1980 mgb heater box MG 2
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
