MGB 1980 MGB carb and oil questions
prc
I'm getting this car running after sitting for 6 yrs and I am looking for a few answers from the experts. What is the recommended oil type and viscosity this takes? It is a 4 cyl 1.8L I think. Also on the carb which is a stock Zenith, the mixture screw has a larger plastic nut and a screw that goes inside of that. When I am adjusting the fuel mixture do I hold the plastic nut from turning or turn them together? Thanks for your help.
paul
drooartz
Oil recommendations can be a bit like starting a religious holy war sometimes, so you may want to search around on the site to read some of the old threads and see the full discussion -- then again, that may not be as fun as it sounds. :crazyeyes:
I run Valvoline VR1 20W50 in my '70 MGB (same engine as yours), and have for the last 11 years. It's one that's pretty widely recommended, and not too hard to find. Amazon has it if all else fails.
Don't know the Zeniths, so someone else will have to chime on on that.
Platinum
Paul, before you start fussing with mixture screws and such, if the car "ran when parked" that shouldn't be a priority. More important would be condition of the piston's rubber diaphragm, inspecting the needle and jet orifice (for any debris from sitting in one position) are of more immediate concern.
As for oil, any good 20~50W will do. All have to "meet or exceed" S.A.E spec's. VR1, Castrol's synths or "High Mileage", Mobil-1, etc. Pick yer poison.
NutmegCT
Paul - congrats on the MG. Attached is a guide on what to check when reviving one. This was created by a former BCF member, RIP.
Tom M.
  • AWAKENING A SLEEPING MGB CHECKLIST.pdf
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
A MGB 1980 MGB MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
M For Sale 1980 MGB for Sale MG Classifieds 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
kyreb1862 MGB 1980 MGB Timing Issue MG 5
Tinkerman MGB 1980 MGB wiring diagram help MG 6
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
Hoosier MGB 1980 MGB Suspension Issue MG 3
M MGB My 1980 MGB [Need some help please!] MG 28
Hoosier MGB 1980 MGB Trunk Lid MG 2
Hoosier MGB 1980 MGB Tail Light Chrome Trim MG 10
M MGB 1980 MGB LE or not?? MG 6
N MGB Question about ignition wiring unique to 1980 MGB MG 15
T MGB 1980 MGB 1800 Motor Color MG 6
D MGB 1980 MGB Roadster . . . Restoration Progress MG 32
K MGB 1980 MGB Seat Colours? MG 2
C MGB Console tunnel - 1977 - 1980 MGB MG 5
JamesWilson MGB-GT New 1980 MGB GT for sale.... MG 9
P MGB 1980 mgb fuel pump MG 3
C MGB looking for 1980 MGB limited edition informaton MG 13
M MGB WILL A 1973 MGB STEERING WHEEL FIT ON A 1980 MGB MG 0
M MGB Shakes at about 3000 RPM 1980 MGB MG 5
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
I MGB 1980 mgb heater box MG 2
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
