    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR2/3/3A TR3A Ignition Switch - new lock/key
angelfj1
I've misplaced the original ignition switch key. :wall:
I have a new lock cylinder/key. How do I remove the original cylinder and install new one?
Frank,
Any reason not to get a replacement key instead?
Scott
You'll need to pick the lock (or take it to a locksmith and let him do it). Fortunately they are trivial to pick. Search Google or YouTube for lots of information on lock picking; but the basic idea is to put some turning force on the cylinder with one tool (a jeweler's screwdriver will do), while you use another tool (bent paperclip) to press each tumbler in turn. The force on the cylinder holds the tumbler in the released position. When they are all released, the cylinder turns.
If you have a blank key, sometimes you can pick the lock by simply inserting the uncut key and holding moderate pressure against the cylinder while withdrawing the key. The trick is to get just the right amount of pressure, so that each tumbler falls back only to it's released position. (And this method doesn't always work.)
With the cylinder in the "On' position, you stick a pin punch or similar through the hole in the side of the housing, to depress the pin that holds the cylinder into the housing. Use a screwdriver or something to pull on the cylinder while depressing the pin.
BTW, once the cylinder is out of the housing, it's pretty easy to cut a key to match.
The other alternative of course is to just replace the whole thing ... chances are good that the original switch and housing are well worn anyway.
HerronScott said:
Frank,
Scott
:iagree: Assuming that there is still a key number on the face, it's very simple to get a replacement key from folks like Pete Groh or "Key-Men"(?), or from some of the major Triumph and other LBC parts vendors...or dial that key number into eBay, where you'll often find original Wilmot-Breeden keys or the occasional Romac replacement key, both having the numbers on the keys.
HerronScott said:
Frank,
Scott
Well, yes I did think of that. What I actually want, is to have the ignition key match the new door and boot locks. :yesnod:
Ah well that makes sense if you are changing those out as well. :smile:
Scott
A TR2/3/3A Correct Coil for petronix ignition tr3A Triumph 2
Q TR2/3/3A Pre-Ignition On TR3A Triumph 9
angelfj1 TR2/3/3A Lucas Ignition Coil for TR3A Triumph 1
Got_All_4 TR2/3/3A TR3A Ignition Problem / Question Triumph 11
RichB4493 Wanted TR3a overdrive dashboard switch Triumph Classifieds 0
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 24
C TR2/3/3A TR3A Electrical problem Triumph 20
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
