bugeye ignition switch
AHBugeye
So, my car was stripped of its wiring harness and most of its electrical parts decades ago. I bought a new ignition switch from Moss. I see in the wiring diagram the terminals are labeled, but I don't see anything on the ignition switch. I've wired it according to the diagram, but all four wires might need to be shifted 90, 180 or 270 degrees. Does any one have reference or knowledge of the wiring for the ignition switch?
gfholl
I believe the white wires should be on the middle connector instead of the blue, so maybe rotate them all one connector counter clockwise? Also having a hard time finding a wired picture of the switch, and can't get a good picture of mine. Hopefully someone else respond to your question as well.
Gary
Bill Young
I have an old Lucas switch in my hand. It looks very much the same as your new one. Looking at your picture, the 12:00 position is marked "A" and should be the brown/blue wire. The 3:00 position is marked "H" and should be the blue wire. The 6:00 position is marked "IG" and should be the white wire(s). The 9:00 position is marked "S&T" and should be the red wire.
Check out the attached wiring diagram.
Bill Young, BJ8, BN2, AN5
sjahc.com
R Bugeye ignition switch Spridgets 2
R Wanted Bugeye ignition switch Spridgets Classified 2
longbridgehealey Bugeye ignition switch Spridgets 4
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
A Bugeye ignition switch Austin Healey 3
longbridgehealey New Bugeye ignition switch question Spridgets 10
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
TulsaFred Bugeye ignition combination switch Spridgets 11
ncbugeye Access to Bugeye ignition switch. Spridgets 3
B Bugeye Ignition Switch Spridgets 2
W Bugeye ignition key repalcement Spridgets 2
I Bugeye 948 ignition timing help please Spridgets 8
I Bugeye ignition light still on- help please Spridgets 35
I Bugeye ignition coil wire help Spridgets 7
L Bugeye Ignition problem Spridgets 12
T Bugeye Ignition Wiring Spridgets 10
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
