Bugeye ignition coil wire help
ichthos
I am getting better at reading the wiring diagram, but I have a long ways to go. I think my diagram shows a white and then a white wire with black stipe going to the ignition coil. If this is correct, can someone tell me which goes to the positive side and which goes to the negative side? How does one tell this from the wiring diagram? Thanks,
Kevin
jlaird
In true fact it makes no difference. Engine will run just fine either way.
dklawson
It will run either way BUT, wired incorrectly you develop lower spark energy.
What goes where depends on the polarity of your car. As built with positive ground, white wire goes to SW (switch) and the white/black wire goes to CB (contact breaker). IF you have switched polarity to negative ground, switch the coil connections.
I
ichthos
Now I understand my wiring diagram better, thanks. I couldn't figure out what the (SW) and (CB) stood for, as there was nothing in the key to tell me.
I don't know if I should start a new questions, but what else would I need to change for a negative ground set up for my car?
Kevin
dklawson
If you are keeping the generator, there is not much that needs to change. The coil was mentioned above. Obviously the battery connections change.
It is imperative that you re-polarize the generator. I believe that process is discussed in Haynes manuals. If not, post back here and one of us will walk you through it.
If you have a electric fuel pump, that has to be dealt with regardless of whether it's an SU pump or an aftermarket pump.
If you happen to have a positive ground radio, that will need to be removed.
If you have added an electronic tachometer, you would need to convert or remove it.
livinginthepast
R Bugeye ignition switch Spridgets 2
R Wanted Bugeye ignition switch Spridgets Classified 2
longbridgehealey Bugeye ignition switch Spridgets 4
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
A bugeye ignition switch Spridgets 2
A Bugeye ignition switch Austin Healey 3
W Bugeye ignition key repalcement Spridgets 2
longbridgehealey New Bugeye ignition switch question Spridgets 10
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
TulsaFred Bugeye ignition combination switch Spridgets 11
I Bugeye 948 ignition timing help please Spridgets 8
I Bugeye ignition light still on- help please Spridgets 35
ncbugeye Access to Bugeye ignition switch. Spridgets 3
L Bugeye Ignition problem Spridgets 12
B Bugeye Ignition Switch Spridgets 2
T Bugeye Ignition Wiring Spridgets 10
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
