T-Series TD/TF Steering Free Play Question
MLMLA
My recently acquired 54 TF has a little free play in the steering. The steering wheel rotates about a half inch before any actual movement of the wheels. Is this normal? If not can it be adjusted or do I need to replace the rack? Thanks.
PAUL161
Not normal. My 55 TF has zero play, none whatsoever and it has the original steering rack! (y)
M
MLMLA
Paul161 - Thanks for your response. I guess I will order the replacement steering rack from Moss and have a good winter project on my hands.
YakkoWarner
I am operating on the assemption that the TD/TF steering is basically similar to the later MG cars - before replacing the rack I'd look at the tie rod ends and pivot bushings. If they are worn you could get the same effect because the rack is moving up the wheels won't turn until the slack in those worn ends gets taken up (been there/done that). Tie rod ends are usually easier and cheaper than a whole rack.
Platinum
Look to the rack mounts in addition to the joints and such. With the car on pavement have someone move the wheel as you observe the rack itself, if it "sways" back and forth, you've found some of the issue. Maybe not all, but worth a try before replacing everything.
MGTF1250Dave
Another place that may cause this problem is connect of the steering column to the rack. There are rubber bushing they may have perished resulting in excessive play at the joint. Addition one or two of the three bolts may come loose or fallen out. I had this problem once.
M
MLMLA
Thanks for all of the suggestions. I have removed the rack and found the steering input shaft bushing is very worn so that the shafts able to wobble significantly. Have all the new parts and getting ready to reinstall the rack. Was quite difficult to remove, hopefully will be able to put the new rack in without having to remove the radiator and other bits.
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
D Steering Column Adjustment Collet Austin Healey 8
W Steering Arm Colors Spridgets 1
BritBite Stiff steering effort Daimler SP-250 Other British Cars 11
Simmo TR2/3/3A Steering with Escort rack Triumph 5
