Wedge FASD wire question
KLUTZ
When I tore down my engine from my recently acquired '80 TR7 to change the head gasket, before I removed the ZS carb setup, I noticed the black and tan wire that plugs into the bottom of the FASD was broken off, just the black smaller wire was attached. I have no idea if the car ran as it should before I got it as I've had a couple different stories from the two PO's. What signal and where does this wire send a signal to? I have re-attached it and I hope it is functionable.
Thanks
Randall_Z
As I understand it, the FASD wires supply voltage to a small heater element inside the FASD which helps atomize fuel until coolant is up to operating temperature, then shut off. There is no signal associated with this function.
bcbennett Wedge TR7 FASD vs. Manual Triumph 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
SNClocks Electrical Wire Lug Spridgets 2
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
P TR5/TR250 Wire wheels width Triumph 8
P Wire Wheel Splines Austin Healey 10
KVH General Tech O/D Electrical Wire Burned Triumph 22
D Wire Wheels and Air Leak Austin Healey 16
S TR2/3/3A wire repair Triumph 7
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
R General TR Emergency hot wire - because you never know whats next Triumph 2
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
S MGB mystery wire MG 32
RJS General TR Wire Wheel Spline Question Triumph 3
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
steveg TR6 Steering boot clamp wire - why? Triumph 2
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
B TR4/4A Wire wheel question Triumph 10
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
T Location of ground wire for BJ8 Austin Healey 6
C What to do about my wire wheels Restoration & Tools 6
P TR5/TR250 wire wheel question Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
K TR2/3/3A Yellow wire uprated condensor Triumph 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Leatherman TR2/3/3A Wire wheel conversion question Triumph 19
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
Rut TR4/4A MWS wire wheels Triumph 9
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
Tullamore Rolls Royce Phantom III Wire Harness Other British Cars 1
I TR6 Gauge/color wire ? Triumph 9
N Enrichener [choke] wire Austin Healey 1
M Chrome wire wheel questions Spridgets 5
