TR4/4A Knock off wire wheels procedure..basic questions
scottkilpatrick
I am new to these on my 62 TR4 - I have gathered some info from the forum but a few questions remain
I want to remove the wheels to analyze and maybe replace the brake pads/shoes.
My guess is that one could use a rubber mallet and whach until tthey are loose? Is that the primary method?
What about putting them back on - I am guessing there is no torque method. Do i just whack until they are tight and stop moving? Also I read somewhere I should use grease when putting them back on. What type of grease and where do i grease?
Thanks all
bobhustead
You need a lead or copper hammer, which were original equipment on wire wheeled cars. A rubber hammer is absolutely not the right tool. Ebay and walmart both offer lead on line. Same tool to install. No torque. There are aftermarket tools that grasp the spinner, but I have no experience with them.
Bob
CJD
Although I do have lead and copper hammers, I found they tend to mar the chrome finish on the nuts. I have been using the rubber side of a rubber flooring hammer (steel hammer with a rubber cover) for many years with good results. I do use a bit of grease on the threads and also the tapered areas where the nut contacts the wheel. Just a thin wipe is all. I also hammer on and off with the wheel off the ground. I think that allows it to seat better, and puts less stress on the spokes. Hammer on until the nut stops turning. If it is going to loosen, it will be in the first few miles, but usually only with new wheels or nuts. Once they have been seated a few times, they tighten easily and have no tendency to loosen. Of course, the corollary to that statement is...if you have relatively new wheels and/or nuts, it is best to check them after the first short trip on the road.
donbmw
I use this for mine.
NeilRogers
Member
Resist the urge to hit them too hard to get them tight as that just destroys the spinner and damages the wheel. The hubs and spinners are right and left handed making the spinners self tightening. If right hand hubs are mounted on the left side and vice versa, the spinners will loosen and likely come off when you drive the car. Be sure to apply some grease to the hub splines as this stops the wheels from rusting onto the splines.
mctriumph
The wooden wrenches work well if you are careful. They will splinter if not affixed nicely.
The trick then, is to pull up on the end away from where you are hitting (and are not
Conan.) This all assumes that you have nice knock-offs and dont want to beat them up.
Clean and grease the splines , if they are sharp , they are no good.....
Mad dog
mctriumph
Little known trick , when the splines are beaten up and sharped from a bad wheel, they can
be worked back into shape with a steel hammer. The splines are not hardened , actually
just mild steel .Careful re-shaping can get you back on the road in a pinch.
Poor men have poor ways.....
Mad dog
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
Editor_Reid Knock-Off Hammer Austin Healey 8
T Knock-Off Spinners Austin Healey 43
TomMull Knock Off Tool Restoration & Tools 6
CJD TR2/3/3A Knock Off Differences Triumph 13
Feathers Knock off wheels for sp250 Other British Cars 6
H General TR Triumph Script Knock-Off Hub Cap Triumph 6
Healey Nut Knock off removal Austin Healey 3
J knock, off tools Jaguar 6
RickB NFI - knock off tool $10 Spridgets 2
Westfield_XI Help, I need a knock off wrench Spridgets 17
britndablood Needed 1 two eared knock off RH side 12 tpi Austin Healey 3
L New Knock-off Spinners Austin Healey 21
Brosky TR6 Custome TR6 Knock-Off wheels....OK.... Triumph 1
T Looking for used set of Knock off minilites Spridgets 4
kodanja Knock it off? Triumph 13
kodanja Knock off grease? Triumph 14
jaybird I need to bribe someone or knock someone off MG 22
M Knock off's......or..... Fall off's MG 6
John Loftus Knock off lettering Austin Healey 14
W knock off Austin Healey 7
G Lead Head Knock-off Hammer Austin Healey 10
S Knock-Off Hub bearings - Can they be removed? Jaguar 1
S Converting from a knock-off to a 5-bolt hub. Jaguar 1
6 Knock off minilites MG 3
Michael Oritt Safety-wiring knock-offs Austin Healey 24
R Knock Rover / Land Rover 1
S TR2/3/3A What a sad day. There is a knock at the door. Triumph 7
HighAltitudeTR3 TR2/3/3A Valve Knock Question Triumph 28
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Knock knock... what's this? Triumph 100
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
steveg Has anyone used a knock sensor? Austin Healey 0
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
S Knock in Transmission/Gearbox Austin Healey 4
S Eared knock-offs - how tight? Austin Healey 19
CJD TR2/3/3A Coarse Vrs. Fine Knock Offs Triumph 5
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
V Panasport Fake Knock Offs Triumph 8
Got_All_4 Wedge Searching for knock offs for TR7 wheels Triumph 2
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
UmmYeahOk Knock Offs - Whats the deal? Triumph 28
prb51 Pinking, Knock, Plinking etc. Triumph 6
R engine knock/ping, retard ignition doesn't help Spridgets 49
DNK KNOCK- KNOCK-KNOCK Triumph 59
MadRiver Octagonal safety knock-offs MG 7
N Starting out in 1st gear knock or clunk Triumph 20
C Wire Knock-offs Triumph 9
