Pinking, Knock, Plinking etc.
prb51
Guys/Gals,
I'm doing my winter tune...a few more degrees advance and a one flat richening of carbs for the cooler air. The TR3 is running well but how does one hear knock in our cars unless it is extreme.
With the valve clatter (open car with brooklands, yes even in winter {Arizona winter}), wind noise, car noise etc how do you detect light knock?
Do you check for this in your garage while parked and no engine load? Will it show up properly under no load?
p.s, my military ears ain't what they used to be either....
Brosky
Get it warmed up and go for a ride. Find a hilly area with quiet streets. Drive as far up the hill as you can in fourth gear, lugging the engine down to low rpms. If it starts to ping early, back off the advance. No ping until you have to shift down, no problem.
Remember that it will first and always occur when the engine is under a load and the best way to duplicate that is above or something similar.
DougF
If your tappets are that loud, there are some options. Temporary options are do nothing or adjust valves. Long term options are to have the rockers and shaft rebuilt or buy new.
Adjusting the valves(if the rocker faces are worn) tighten up your clearances a thousandth or two. Over time, the face of the rocker forms a groove where it makes contact, and tightening the clearances can help offset this wear.
If your engine is fairly new, adjust the valves as per factory spec.
If the rocker shaft shows excessive wear at the bottom were the rocker rides, replacement or rebuilding are the only options. Excessive wear can alter the rocker ratios and cause poor performance. Very excessive wear can cause binding and really alter engine performance.
I recently had the rockers rebuilt on my TR6. The company reamed, bushed and refaced the rockers to the original ratio. I had already purchased a new shaft. It eliminated all valve clatter and increased performance nicely. I consider it money very well spent. Rebuilding was less expensive than new.
prb51
prb51
Some day I'll get them rebuilt but the car runs really well as is. I use an extremely slim gauge (thinner than the rod head ) to measure and they're set properly...they just clatter a tad.
What did it run for a rebuild approx?
DougF
For me to just have the rockers done and I gave him a core rocker shaft, with shipping was around $175. A friend of mine had everything done on a Bugeye for I think a little less.
I thought my car ran pretty well also, but the difference was very surprising. It now runs perfectly smooth at idle.
I had this shaft built for an engine I plan to build over the winter. Somehow it doesn't seem right to pull a perfectly running engine out and replace it with a new project.
prb51
prb51
Doug,
Decent price for the work and I suspect I'll get around to it (after my tranny upgrade).
I took the car to a steep side street and lugged her up in 4th and couldn't hear anything different noise wise so I'll stick with what I've got.
I agree about your engine if it's 'right' as is. Just rebuild the other and have a 'stand by'. I'd not rebuild it to have it sit though, I'd wait until the other needed freshening so everything will remain tight.
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
T Knock-Off Spinners Austin Healey 43
Michael Oritt Safety-wiring knock-offs Austin Healey 24
TomMull Knock Off Tool Restoration & Tools 6
R Knock Rover / Land Rover 1
S TR2/3/3A What a sad day. There is a knock at the door. Triumph 7
HighAltitudeTR3 TR2/3/3A Valve Knock Question Triumph 28
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Knock knock... what's this? Triumph 100
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
CJD TR2/3/3A Knock Off Differences Triumph 13
steveg Has anyone used a knock sensor? Austin Healey 0
Feathers Knock off wheels for sp250 Other British Cars 6
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
S Knock in Transmission/Gearbox Austin Healey 4
S Eared knock-offs - how tight? Austin Healey 19
H General TR Triumph Script Knock-Off Hub Cap Triumph 6
CJD TR2/3/3A Coarse Vrs. Fine Knock Offs Triumph 5
Healey Nut Knock off removal Austin Healey 3
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
J knock, off tools Jaguar 6
V Panasport Fake Knock Offs Triumph 8
RickB NFI - knock off tool $10 Spridgets 2
Westfield_XI Help, I need a knock off wrench Spridgets 17
Got_All_4 Wedge Searching for knock offs for TR7 wheels Triumph 2
britndablood Needed 1 two eared knock off RH side 12 tpi Austin Healey 3
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
L New Knock-off Spinners Austin Healey 21
Brosky TR6 Custome TR6 Knock-Off wheels....OK.... Triumph 1
UmmYeahOk Knock Offs - Whats the deal? Triumph 28
T Looking for used set of Knock off minilites Spridgets 4
R engine knock/ping, retard ignition doesn't help Spridgets 49
DNK KNOCK- KNOCK-KNOCK Triumph 59
kodanja Knock it off? Triumph 13
MadRiver Octagonal safety knock-offs MG 7
N Starting out in 1st gear knock or clunk Triumph 20
kodanja Knock off grease? Triumph 14
C Wire Knock-offs Triumph 9
jaybird I need to bribe someone or knock someone off MG 22
M Knock off's......or..... Fall off's MG 6
John Loftus Knock off lettering Austin Healey 14
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
TR4 Wire Wheel Knock Offs???? Triumph 13
EMGEBE TAT TAT TAT TAT TAT [engine knock?] MG 13
W knock off Austin Healey 7
R Best price for Minilite Knock-offs? MG 8
