TR4/4A TR4A IRS Rear Suspension Knock
KVH
On my IRS, which has a lightened flywheel and a LSD Nissan differential, I'm experiencing some great handling and driving, but I'm also feeling what seems to be a slight knock (like a little kick in the tail) when I shift into second or third at hight RPMs.
Am I hearing a U-Joint issue? I guess there are six to worry about (2 at the driveshaft and 2 at each axle shaft) Something else?
tdskip
Hopefully just u-joints. The IRS has the same differential mounts as the TR6, and the pins and mounts should be checked. Have you check those yet?
poolboy
When you are torquing good, say in 2nd or 3rd around 3300 and let off the gas suddenly, do you hear it ?
RJS
Ah, there's a lot going on back there so potential for one of several issues. It would be good to hear more detail on the noise and exactly under what conditions you hear it. Possibilities include:
1) differential mount pins (usually heard pulling away in 1st gear)
2) u-joints as suspected (usually heard puling away in 1st gear)
3) sticking splines in the axle shaft slip joints (this occurs when letting off the power during a long sweeping turn. The torque tends to keep unlubricated slip joints stuck until the foot is raised off the gas and "jink" they slide just that little bit with a very odd sensation in the rear end).
4) trailing arm bushings
1) and 2) usually result in a knock or cluck. 3) and 4) actually can give a twitch in the handling.
Bob
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
G TR4/4A tr4a irs left rear wheel Triumph 14
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
KVH TR4/4A TR4A IRS Rear Spring Bridge Triumph 6
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
J Wanted Tr4a irs frame Triumph Classifieds 1
L For Sale late tr4a IRS project Triumph Classifieds 0
Scotsman TR4/4A TR4a Live axle vs IRS Triumph 13
J TR4/4A TR4A IRS Grille Question Triumph 4
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
C TR4/4A TRIUMPH TR4A iRS For Sale - NUT & BOLT RESTORATION--[CONCOURS CONDITION] Triumph 2
C TR4/4A 1967 TR4A IRS motor mounts Triumph 7
Zimmycobra TR4/4A TR4A IRS Differential Mounts Triumph 8
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
rovernut TR4/4A TR4A IRS VIN differences Triumph 9
T TR4/4A 65 triumph tr4a-irs tires Triumph 7
J TR4/4A TR4A IRS Trunk Triumph 3
J TR4/4A TR4A IRS Exhaust Triumph 5
T TR6 TR4a IRS vs TR6 handling Triumph 20
J TR4/4A TR4A IRS Clamps, Belt and Suspenders? Triumph 4
J TR4/4A TR4A IRS Exhaust Triumph 11
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
J TR4/4A TR4A IRS Jack Stands Triumph 6
J TR4/4A Shock Absorbers TR4A IRS Triumph 3
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
R TR4/4A Tr4a irs, name plate question Triumph 13
J TR4/4A 67 TR4A IRS Hood Bumpers-Cones or Flat? Triumph 8
gubba TR4/4A My new 1967 TR4A IRS Triumph 17
J TR4/4A TR4A IRS Home Triumph 5
J TR4/4A 67 TR4A IRS picked up today! Triumph 23
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
RJS TR4/4A TR4A IRS Diff Capacity Triumph 3
T TR4/4A Fired the 67 TR4a IRS engine today Triumph 5
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
Darrell_Walker TR4/4A TR4A IRS-SC?!?!?! Triumph 48
KVH TR4/4A TR4A IRS Differential and Axles Removed Triumph 11
KVH TR4/4A TR4A IRS Issues and Smashed Thumb Question Triumph 24
KVH TR4/4A TR4A IRS Axle Shafts Triumph 19
T TR4/4A TR4a IRS differential mount issues Triumph 11
T TR4/4A TR4A IRS trailing arm bushing question Triumph 15
bcliff TR4/4A Triumph TR4A IRS FS. Need help with this one.PICS! Triumph 6
