TR4/4A 1967 TR4A IRS motor mounts
canyon77
The motor mounts on my '67 TR4A IRS are detiorated. The rubber is splayed away and the engine is resting on the metal interior of the mount (both sides) Could this metal to metal contact cause a chasis shudder on rough roads? Is this worth fixing and can it be done with the engine in? I just did major front suspension rebuild incl. TR6 bracket upgrade. Having pronounced chasis shudder on rough roads.
1967 TR4A IRS Sunday driver
1962 TR4 (deceased)
1967 TR4A (solid axle, factory surrey top, wire wheels) stolen
sail
I think you found the reason for your shudder. You can raise the engine with a jack and board under the oil pan to replace the mounts. It will take tilting the engine from one side to the other, kinda tight. If the fronts are that bad it would be worth checking the third mount under the tail of the gearbox. A bad one of those will also make quite a shudder but it's harder to get at. Pretty sure the radiator hoses need to come off.
KVH
Here's what I did (twice):
a) Drained the radiator and removed the upper and lower hoses;
b) Raised car on jack stands and removed both front wheels;
c) Slightly loosed the two rear transmission mount nuts under the car;
d) Removed one motor mount nut, and loosened the other
e) Raised engine from sump with block of wood at the far front of the sump where it's strong;
f) Prayed I got the engine high enough to pull out the mounts, one at a time
(I might have also removed the water pipe that goes to the lower hose since that was blocking my access to the driver's side mount)
Yes, I ended up tilting the engine a bit, and I'd recommend trying to keep one engine mount nut partially "on" so you don't end up with an engine in the air that won't drop down on the mounts.
That happened to me, and it was a scare. I gobbed up the mounts and the protruding bolt heads with grease and somehow everything slid into place. Can you imagine somehow getting the engine and inch or so off center, and there it is on your jack?
Anyway, maybe I worried more than needed--since it dropped right back down. Just be careful, and have fun deciding which new mounts to use.
RJS
I replaced my motor mounts as they were sagging and allowing the fan hub to rub on the cross brace. Used new HD mounts from BPNW. I was shocked at the smoothness of the entire car after the replacement. It was like driving a new car.
Bob
MichaelG
Yes, very important to do one at a time. If you place the block of wood off center on the pan it will tilt the engine as lifted. Don't tighten the nuts until both new mounts are in place.
Look for a thick metal washer on the bottom of the old mount...it is not part of the old mount.....this needs to be removed and refitted under the new mount....
This job is much easier if using a 24' extension-ujoint-socket combination, as you can get to the engine nuts from above.
Great time to replace the fan belt if there is any question about age or condition...I have to loosen the mounts and raise the engine an inch or so to replace my belt, and believe it is true for most 4A's with original thick belt.
Good luck
alanjohnturner
The above is all absolutely right. Especially the bit about the fan-belt.
Its a crazy piece of design, but this won't pass over the pulley and past the cross-brace with the engine in its proper place.
So sort it out while doing the mountings.
If you run for log with a poor rear-mounting you can wind up with a crack in the exhause manifold. You will regret this!
Al.
C
canyon77
Wow! Great info and detail. Great forum; I'll be putting this at the top of my to do list. Will let all know how it goes. After the front suspension rebuild Fergus is enjoying the California canyon roads. Hope to return the favor.
Shiny side up, Canyon
TR4A_IRS
A little late to the party, but you may want to consider the earlier style (round) monts, as they are a bit taller than the square TR4A mounts. I went this route to get the proper cearance between the fan hub and steering rack. As a side benefit, I can now change a fan belt without a jack.
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
gubba TR4/4A My new 1967 TR4A IRS Triumph 17
6 TR4/4A 1967 Triumph TR4A IRS Triumph 2
T TR4/4A 1967 TR4A IRS - How much are they worth? Triumph 10
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
Stinger TR4/4A 1967 TR4A Finished !! Triumph 22
Stinger TR4/4A 1967 TR4A For Sale $6500 Triumph 1
T 1967 Tr4a no spark FORUM Navigation Questions 2
M_Pied_Lourd TR4/4A 1967 TR4A Question Triumph 35
M MGB 1967 MGB starter conversion MG 9
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
T MGB-GT cant rails on 1967 MGB GT MG 12
AUSMHLY 1967 Mark III, Phase I through III and counting Austin Healey 38
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
C Spitfire 1967 Triumph Spitfire Triumph 2
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
mch979 1967 MGB GT bonnet issue MG 25
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 4
S For Sale Triumph TR5 Factory Parts Manual on CD/ROM - 1967 to 1968. Triumph Classifieds 0
S For Sale Triumph TR5 Factory Workshop Manual on CD/ROM - 1967 - 1968 Models. Triumph Classifieds 0
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
S For Sale Sunbeam Tiger Factory Workshop Manuals – 260 and 289 Models - 1964 - 1967 Other British Classifieds 0
S For Sale MGC Factory Workshop Manual on CD/ROM - 1967 - 1969 Models MG Classifieds 0
S For Sale Morris Minor Factory Workshop Manual om CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
M MGB 1967 MGB seats MG 9
T 1967 BJ-8 Kick Panels Austin Healey 1
G For Sale 1967 bj8 Austin Healey Classifieds 0
longbridgehealey 1967 sprite earth? Spridgets 12
S New Member 1967 Austin Healey 3000 Austin Healey 5
H 1967[?] Austin FX4 London Taxi Other British Cars 3
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
F For Sale Beautiful 1967 Triumph Bonneville T-120 Triumph Classifieds 1
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
G rear wheel studs on my 1967 BJ8 Austin Healey 5
AH67 General TR 1967 Triumphm 2000 no ignition Triumph 5
AH67 General TR 1967 Triumphm 2000 Triumph 7
R Rewiring a 1967 3000 Austin Healey 17
M Overdrive In-Op AH BJ8 1967 Austin Healey 11
Editor_Reid Fuel Gauge for 1967 Sprite Spridgets 4
D Recommendation for new core in original 1967 Austin Healey radiator Austin Healey 5
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
M TR5/TR250 Where were you on this day in 1967? Triumph 19
Sopwith_Camel was this wire brown in 1967? Jaguar 5
D Need Some Advice on My 1967 BJ8 Austin Healey 8
Marvin Gruber 1967 BJ8 out of the barn Austin Healey 8
Rut TR4/4A 1967 commission number decoding Triumph 16
S 1967 3000 MK3 BJ8 Suspension is so stiff - any chance to improve comfort ? Austin Healey 10
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
