was this wire brown in 1967?
Sopwith_Camel
ok so im tring to get the radio back in to the 340 aka MK2, the hanes manual says there is a brown wire going to the radio Junction from the ampmeter. so what is a radio junction? so i run the radio off the ammeter?
I have a wire that that might have been brown in 1967, going from the ampimeter to some where and now that is snapped off so somewhere I might have a wire end hitting the fire wall. joy. so thats the for the radio? its not visibly part of a harness.
I got a sunny week end coming up. should be able to get the new gas tank in.
oh and the wood trim might go back in.
LarryK
Watch the brown wires. Had a 73 GT6 that I redid the tranny and on reinstalling had left the brown wire to the radio hanging. Told wife NOT TO USE heater fan for air movement until I could plug it in the next day. Little heed was my warning, burnt the dash harness on her way home from work and I then spent the whole night rewiring the whole dash and ignition. Nothing was reusable and luckily I had a second car for a harness.
Sopwith_Camel
Sopwith_Camel
thanks so you agree that was a full brown in 1967 and should go to the radio.
the car has been on fire once this year.
what i would like to do is run the radio through one of the jag 3 postion switches so that it has no power. power when i use the Ipod. and power and anttena in the top postion so far no luck getting that combination.
LarryK
Purple/Red is a switched hot wire.
maynard
The usual description of a brown wire is hot at all times and not fused.
Sopwith_Camel
Sopwith_Camel
I have two wires from the radio (retro sound) yellow that says battery and red that says 12volt accessory.
so i have the yellow run to the battery and the red to the ampameter is that right?
or should it be yellow to brown and red to purple/red
steve
tinman58 General TR It was just a loose wire Triumph 15
G GM Module in Lucas box [ was PICKUP COIL + wire?] Spridgets 5
AngliaGT "I WAS SEVENTH!" Racing 0
mezy Look what I was in yesterday Other Cars 14
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
S TR2/3/3A my OD stopped working after it was working Triumph 25
dougie Use your car as it was meant to be used Austin Healey 15
drooartz General MG Surprisingly enough, I was right! MG 7
JPSmit well that was fun Spridgets 1
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
Gliderman8 General MG The car that never was MG 6
Got_All_4 TR6 This frame was sectioned Triumph 9
S TR2/3/3A and the radiator was leaking. Triumph 7
Jim_Gruber Boy was I ever surprised on Saturday Spridgets 11
K TR2/3/3A It was all going so well....... Triumph 11
tinman58 General TR Well that was close! Triumph 12
T Was Sophia Loren ever photographed with a Healey? Austin Healey 2
Trevor Jessie When was the last time you bled your brakes? Spridgets 4
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
HealeyRick DMH was a Nasty Boy Austin Healey 2
catfood So thats what it was... Other British Cars 0
Zitch TR4/4A Door Weather Strip Channel - Was this added? Triumph 4
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
T Was the Bugeye a Mk I from the get-go? Spridgets 9
PC Dang, that was too good to be true... Restoration & Tools 3
Jim_Gruber Bugsy was out for his first real romp today! And it was fun!!!! Spridgets 3
JPSmit Tesla - but that's not what was interesting Other Cars 2
H At least the Bugeye Shirt was at the HPDE this weekend. Spridgets 5
drooartz MGB Today was a good day - the MGB is legal! MG 6
longbridgehealey When did you buy your first LBC, and what was it? Spridgets 46
S What was it? Other Cars 18
J Cloth interior in AH-3000? Was it ever fitted? Pleated inserts maybe? Austin Healey 7
GTP1960 TR2/3/3A It was running great....until Triumph 17
CZ_Dave MGB Was I missed? MG 2
bighealeysource Was 100M from Chasing Classic Cars sold this weekend? Austin Healey 20
S TR2/3/3A 37XXX and 27XXX the steering column was split Triumph 6
C The 1956 Jaguar XKSS was one of a kind Jaguar 10
H Aston Martin DB4 converible found in UK awhile back--what was paid for it? Other British Cars 0
C Was the 2013 Jaguar XJ Ultimate the Crown Jewel of Luxury? Jaguar 0
C Just how good was the Jaguar E-Type? Jaguar 10
JPSmit What was on the trailers was most interesting today Spotted 2
DanLewis And I thought the Bugeye was small... Spridgets 6
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
S What Was it Like? Spridgets 10
krswen Remember when carb cleaner was so strong .... Restoration & Tools 12
HealeyRick Wedge It Was All the TR7's Fault Triumph 7
DNK Was this real to start? Lotus 7
RickB I was wrong. Again. Not ignition switch! Spridgets 16
RickB Thought I saw a 210 - but it was just a B Spridgets 6
