TR2/3/3A 37XXX and 27XXX the steering column was split
sp53
Somewhere between 37XXX and 27XXX the steering column was split in two on a tr3. The tub I want to use is 27XXX and so is the frame, but I want the split column. It looks like I need a bracket welded on the frame 27XXX frame and some bolts/nuts onto the fire wall for the back bracket on 27XXXX tub to fit a spit column The split column should be adaptable to the early tub 27XXXX because 37XXX tub is where the split column come off of and is basically the same tub and is before the big change at 60,000. Anyways if this not too confusing, I would like to go with the 27XXX tub and split column and want know what others think.
S
sp53
That is what I thought too Marv, but sometimes I am wrong. There is some difference in length, but that should hide where the column comes out of the dash.
CJD
The bracket for the split column is on the frame tower, not the tub. If you're using the split frame, there is no tub difference.
S
sp53
I restored a 61 once, and I kinda remember some bolts coming through the cab on the back part of the columns second/top piece, but I am not sure. I will try looking for some pics or are you saying John that like a 59 or so with pre 60K ts number did not have a bracket in the back and just the one under the dash?
vivdownunder
The split column steering after TS34533 had 2 x additional brackets -
An (aforementioned) half moon bracket welded to the spring tower to brace the lower column.
A dogleg shaped bracket which bolted to the engine side of the firewall to support the lower end of the upper column.
For wiggle room, leave these brackets finger tight until the columns are aligned and the stator tube passes through cleanly.
Viv
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
D Steering Column Adjustment Collet Austin Healey 8
W Steering Arm Colors Spridgets 1
BritBite Stiff steering effort Daimler SP-250 Other British Cars 11
