When was the last time you bled your brakes?
I try to bleed mine every 2-3 years.
Why?
1. If you are using regular glycol based brake fluid it absorbs water and can cause cylinder walls to rust ... and that leads to brake failure. There can also be a build up of rubber debris from seals and rubber hoses... and that can lead to brake failure.
2. If you are using silicone fluid, then water can condense in the system and work its way into the cylinders and again cause rust...and that leads to brake failure. The bigger problem with the silicone fluid is that it doesn't lubricate as well and the rubber seals in the cylinders degrade and collect and clog lines...and that can lead to brake failure.
Of course you should also visually inspect your brake hoses every year as well. Replace any that show signs of damage or are older than 10 years old.
I'm working on a bugeye that has silicone brake fluid, teflon brake hoses, and disk brakes in the front. The attached picture shows what was flushed out of the brake/clutch system. To my knowledge, the brakes have not been bled in at least two years.
Trevor Jessie
Let's add one other issue. With silicone brake fluid, there is anecdotal evidence the the brake light switch does not last as long. The switch still works on the Bugeye that I am currently working on, but it takes significant pressure to activate (am not sure if that is due to the silicone or the age of the switch). On my Bugeye I have a pedal activated switch. I like for people to know the second I tap my brakes.
glemon
I agree about the possible water issues, I had a 7 year old master cylinder fail in my Triumph, silicone fluid, was assuming I could rebuild, was a line of corrosion down the bottom of the cylinder, as if the water pooled down there.
I don't agree about silicone being a worse lubricant, I have about 20 years of driving LBCs with Castrol LMA, and the next 20 with DOT 5. Replacement of master and slave cylinders was a common occurrence, every year or two something would go out, often a rear slave cylinder, but other parts as well. The last 20 years after using silicone the above mentioned master cylinder is the only one I can recall.
I wouldn't call this scientific research by any means, and the first twenty years there was much more daily driver activity, the last 20 more sheltered life and lower miles, but nevertheless, the stuff does not seem to wear out components faster to me.
But once again, do agree totally about flushing the fluid.
Trevor Jessie
I guess I shouldn't claim that the lack of lubricity causes premature wear. But I think I could prove that silicone fluid does do not lubricate as well as DOT 4.
twas_brillig
A quick commercial for the best possible LBC upgade: LED tail/brake/signal lights. Also for any other classic motor vehicle. Doug
JPSmit Last night was driving on the highway Spridgets 1
J Will the New F type Jaguar be mid engined or front engined..the last report was..... Jaguar 2
AngliaGT "I WAS SEVENTH!" Racing 0
mezy Look what I was in yesterday Other Cars 14
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
S TR2/3/3A my OD stopped working after it was working Triumph 25
dougie Use your car as it was meant to be used Austin Healey 15
drooartz General MG Surprisingly enough, I was right! MG 7
JPSmit well that was fun Spridgets 1
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
Gliderman8 General MG The car that never was MG 6
Got_All_4 TR6 This frame was sectioned Triumph 9
S TR2/3/3A and the radiator was leaking. Triumph 7
Jim_Gruber Boy was I ever surprised on Saturday Spridgets 11
K TR2/3/3A It was all going so well....... Triumph 11
tinman58 General TR Well that was close! Triumph 12
T Was Sophia Loren ever photographed with a Healey? Austin Healey 2
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
HealeyRick DMH was a Nasty Boy Austin Healey 2
catfood So thats what it was... Other British Cars 0
Zitch TR4/4A Door Weather Strip Channel - Was this added? Triumph 4
tinman58 General TR It was just a loose wire Triumph 15
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
T Was the Bugeye a Mk I from the get-go? Spridgets 9
PC Dang, that was too good to be true... Restoration & Tools 3
Jim_Gruber Bugsy was out for his first real romp today! And it was fun!!!! Spridgets 3
JPSmit Tesla - but that's not what was interesting Other Cars 2
H At least the Bugeye Shirt was at the HPDE this weekend. Spridgets 5
drooartz MGB Today was a good day - the MGB is legal! MG 6
longbridgehealey When did you buy your first LBC, and what was it? Spridgets 46
S What was it? Other Cars 18
J Cloth interior in AH-3000? Was it ever fitted? Pleated inserts maybe? Austin Healey 7
Sopwith_Camel was this wire brown in 1967? Jaguar 5
GTP1960 TR2/3/3A It was running great....until Triumph 17
CZ_Dave MGB Was I missed? MG 2
bighealeysource Was 100M from Chasing Classic Cars sold this weekend? Austin Healey 20
S TR2/3/3A 37XXX and 27XXX the steering column was split Triumph 6
C The 1956 Jaguar XKSS was one of a kind Jaguar 10
H Aston Martin DB4 converible found in UK awhile back--what was paid for it? Other British Cars 0
C Was the 2013 Jaguar XJ Ultimate the Crown Jewel of Luxury? Jaguar 0
C Just how good was the Jaguar E-Type? Jaguar 10
JPSmit What was on the trailers was most interesting today Spotted 2
DanLewis And I thought the Bugeye was small... Spridgets 6
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
S What Was it Like? Spridgets 10
krswen Remember when carb cleaner was so strong .... Restoration & Tools 12
HealeyRick Wedge It Was All the TR7's Fault Triumph 7
DNK Was this real to start? Lotus 7
RickB I was wrong. Again. Not ignition switch! Spridgets 16
