Another question 1967 BJ8 top installation,metal retaining strip
dmorris1
Member
Hi Everyone,
I'm installing a everflex Robbins top and watching the Moss video. They show a metal retaining strip attaching the everflex fabric to last bow of the frame and screw in. Did all frames come with this metal retaining strip? There are no holes in my frame.Where can you buy one?
Thanks,
David
Legal Bill
Yes. The strip is attached to the inside face of the bow so it is clearly visible from inside the car. Check part number 806-195 in the moss catalogue.
K TR2/3/3A Another brake bleed question....... Triumph 17
D TR2/3/3A Another Carb question. Triumph 22
Lin Another Trafficator/Control Head Question Austin Healey 10
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
B Another OD question Austin Healey 32
Y MGB Another question - this time on seatbelts.... MG 2
D TR6 Another Newb Question Triumph 10
C Another leak, another question... Austin Healey 20
K TR2/3/3A Another Steering Question... Triumph 17
CLEAH Another BJ8 Misfire Question Austin Healey 11
B Another disc brake question Spridgets 10
K TR2/3/3A Another windshield question...bolts and screws? Triumph 15
D Another Valve Guide Question Austin Healey 1
D MGB another spring question MG 1
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
B TR2/3/3A Another Steering Box Question Triumph 29
Healey Nut Another drain channel question . Austin Healey 21
M TR4/4A Another question on window regulator. Triumph 3
R Not just another throw out bearing pin question Austin Healey 3
J Another what cooling fan is this question? Austin Healey 47
D Not another oil pump question. Austin Healey 7
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
T TR2/3/3A another brake master cylinder question Triumph 16
P TR6 Another eletrical question [uugh!] Triumph 5
M TR2/3/3A Another seat belt question Triumph 8
longbridgehealey Another I just don't understand electricity question Spridgets 6
fpstude TR4/4A Another Wiper Question - Very Sluggish Triumph 12
Morris Another wheel bearing question Spridgets 3
Griz Another BJ7 Wiring Question Austin Healey 4
MarshgrassA Another Dealer 100M question Austin Healey 13
John Turney Another picture question FORUM Navigation Questions 0
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
S TR2/3/3A Another Amp Meter & Regulator Question - TR3A Triumph 19
Geo Hahn TR2/3/3A Yet Another TR3A Slave Cyl Question Triumph 4
A another master cyl question Triumph 4
B Another wiring question 57 smallmouth control head Triumph 2
R Another insulation question Austin Healey 3
tri_carb_healey another outrigger question Austin Healey 18
Jim_Newman Another little electrical question - fuel gauge. Austin Healey 3
M Another Tonneau question Spridgets 12
E another dumb electrical question Austin Healey 8
longbridgehealey another 1275 from 948 question Spridgets 3
jlaird Another stupid question from your old friend Spridgets 18
regularman another 1500 question Spridgets 10
nevets another SU fuel pump question Austin Healey 10
I another adjustable steering column question Austin Healey 8
