Another OD question
BruceAllcorn
I have a 1962 tri-carb with an overdrive that I am running Redline MT-90 in. When I flip the switch to switch it into OD there is a delay of 1.5-2.0 seconds before the OD drops in. If I am accelerating from a stop with the OD on, when I get into 3rd gear the OD will have dropped out and will not re-engage until I have built some RMP's. If I am slowing down and shift into 3rd gear it will often drop out of OD and once I accelerate and the RPM's get higher it will again engage. I have just enough play in the gear shift lever to be able to "engage" the OD switch on the gearbox while in 3rd or 4th gear to disengage the OD, but in my normal shifting this does not come into play so I don't think that a worn gear shift lever bushing or a bad overdrive switch are the problem. Any ideas as to what is/are causing this problem?
John Turney
My first thought is that the pump is worn.
When you accelerate from a stop, the OD disengages in 1st or 2nd. But having to build RPMs to get it to engage in 3rd or 4th means low oil pressure in the OD.
Keoke
When you accelerate from a stop, the OD disengages in 1st or 2nd. But having to build RPMs to get it to engage in 3rd or 4th means low oil pressure in the OD. ----
-Yep: I agree, check OVD pressure builds up quickly to 450 PSI.
Healey Nut
If the screen filter in the OD is clean then you need to check the OD oil pressure 450psi min . Probably need an OD overhaul . New piston rings and operating ball/spring etc .
B
BruceAllcorn
It seems to be a concensus and is the way I was leaning also. Thanks for the answers. Any suggestions on who to get to rebuild the OD?
Healey Nut
Check the oil pressure before you decide to rebuild . It could be a dirty screen in the OD .
if you decide to do a rebuild , do it yourself its just an oil pump with a diverter valve ,the hardest part is getting it back on the gearbox due to the double spline arrangement. Thats a patience tester .
Keoke
Check with Bruce @ Healey Surgeons
OR:
Billy @ White Post in White post Virginia
CraigC
The recommendation to check the oil pressure is key here. If the pressure drops much below 450 psi, a lot of odd behaviors will show up.
From personal experience, the first culprit to consider for the pressure decline is the accumulator spring. Over time, they weaken and the pressure drops. The spring is replaceable without removal of the OD unit. It is behind the cover on the left side.
In my case the overdrive quit engaging but would kind of "freewheel" if I let off the gas slightly. Measured pressure was in the 350 psi range. Ordered a spring and the side cover gasket from Moss. The new spring was noticeably longer than my old one. After replacement, pressure was up to the 450 psi spec and OD operation was back to normal.
The pressure gauge setup is a bit out of the ordinary as it needs to install into the operating valve plug. I purchased mine from J Holekamp whose gauges are shown in this link https://www.healey6.com/Technical/OD Gauge.pdf. His e-mail address is jholekamp@sbcglobal.net. I don't recall the price, but it was not unreasonable.
RestoreThemAll
Quantum Mechanics, Oxford CT was recommended to me by folk on this forum. John rebuilt my OD. Parts or full service. Check their website.
RestoreThemAll
Number 35 in the pic.
From AH Spares website
RestoreThemAll
Number 35a is the screen
roscoe
All of these things may be possible. One thing that is easy to check if you do have low oil pressure is the seat for the ball bearing which is for pressure relief of the piston type oil pump that runs the OD oil pressure. I know this may be beyond what you feel like doing, it requires removing the side cover after draining the oil. I found bad pitting of the seat and wear of the ball bearing was the cause of my never building sufficient oil pressure, even at higher revs. . Lapping the little seat with a new ball bearing glued to a piece of round 1/4 inch stock and chucked in a drill. Valve grinding compound worked very well. Coarse first then fine. The ball bearing is #36 in the diagram that was posted above. I've posted a photo of the pressure gage I made. The threaded portion is a spare operating valve cap with a small hole drilled through the top, item 28A in the diagram, welded or brazed to a pipe fitting to adapt it to a glycerin filled gage. Just replace the in service cap with this and drive and you see the OD oil pressure and it does not affect the operation. IMG_20190131_142944658-585x1040.jpg
Good point. There's a similar ball/seat valve on the shaft that is moved by the activation cross-shaft's cam (I believe it's what allows the pressurized accumulator fluid to move the cone clutch against the brake ring and lock the sun gear). I think if this valve didn't seal it would relieve some of the pressure necessary to activate the O/D. I rebuilt my O/D last year and, IIRC, the shop manual's recommended technique for seating the ball in the seat is to give it a good smack with a hammer and drift (maybe not the exact instructions).
Side note: As far as I can tell, every incidental ball bearing--O/D valves, seat runners, and others--is 5/16". I bought a boatload from an online supplier of (only) ball bearings.
Thanks for the info...so if there is crud in the screen it can affect how the OD engages /disengages?
If it's sludge, yes. If there's metal in it the O/D should be rebuilt. I've seen some stuff that looks like coffee grounds--just a pinch or two--and it didn't seem to cause any problem (could be clutch material).
Healey Nut
Any restriction (dirty screen)or leakage due to worn OD piston rings or ball seats will affect flow and how much pressure the OD oil pump produces , all this will affect the operation of the OD and dont forget the gearbox and OD share the same oil .
Addendum to my previous reply: 'Crud' in the screen does not necessarily require an overhaul of the unit; as Nut points out the O/D and gearbox share fluid, so metal could have come from the gearbox (somewhat normal as synchros, etc. wear). You might get by with a good flush and fluid refill, but if either is making a lot of metal, and you want a reliable car, at least a teardown and inspection is a good idea.
K TR2/3/3A Another brake bleed question....... Triumph 17
D TR2/3/3A Another Carb question. Triumph 22
Lin Another Trafficator/Control Head Question Austin Healey 10
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Y MGB Another question - this time on seatbelts.... MG 2
D TR6 Another Newb Question Triumph 10
C Another leak, another question... Austin Healey 20
K TR2/3/3A Another Steering Question... Triumph 17
CLEAH Another BJ8 Misfire Question Austin Healey 11
B Another disc brake question Spridgets 10
K TR2/3/3A Another windshield question...bolts and screws? Triumph 15
D Another Valve Guide Question Austin Healey 1
D MGB another spring question MG 1
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
B TR2/3/3A Another Steering Box Question Triumph 29
Healey Nut Another drain channel question . Austin Healey 21
M TR4/4A Another question on window regulator. Triumph 3
R Not just another throw out bearing pin question Austin Healey 3
J Another what cooling fan is this question? Austin Healey 47
D Not another oil pump question. Austin Healey 7
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
T TR2/3/3A another brake master cylinder question Triumph 16
P TR6 Another eletrical question [uugh!] Triumph 5
M TR2/3/3A Another seat belt question Triumph 8
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
longbridgehealey Another I just don't understand electricity question Spridgets 6
fpstude TR4/4A Another Wiper Question - Very Sluggish Triumph 12
Morris Another wheel bearing question Spridgets 3
Griz Another BJ7 Wiring Question Austin Healey 4
MarshgrassA Another Dealer 100M question Austin Healey 13
John Turney Another picture question FORUM Navigation Questions 0
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
S TR2/3/3A Another Amp Meter & Regulator Question - TR3A Triumph 19
Geo Hahn TR2/3/3A Yet Another TR3A Slave Cyl Question Triumph 4
A another master cyl question Triumph 4
B Another wiring question 57 smallmouth control head Triumph 2
R Another insulation question Austin Healey 3
tri_carb_healey another outrigger question Austin Healey 18
Jim_Newman Another little electrical question - fuel gauge. Austin Healey 3
M Another Tonneau question Spridgets 12
E another dumb electrical question Austin Healey 8
longbridgehealey another 1275 from 948 question Spridgets 3
jlaird Another stupid question from your old friend Spridgets 18
regularman another 1500 question Spridgets 10
nevets another SU fuel pump question Austin Healey 10
I another adjustable steering column question Austin Healey 8
