engine knock/ping, retard ignition doesn't help
recordsj
I have a 1500 midget, pertronix ignition, weber 32/36 carb.
I have an issue of engine knock/ping. It is more noticable at idle and lower revs (<3000 rpm). I replaced the spark plugs and wires, which didn't help. The timing is set 10 BTDC. I tried retarding the ignition, but the knock/ping is still there. Any ideas?
JPSmit
I'm not near my manual right now but I am pretty sure that 10deg BTDC is for 1275's and 1500's are actually 2 deg ATDC - I'll check when I'm in the garage to confirm
Jim_Gruber
PRemium Gas please not 87 octane
JPSmit
even for a low compression 1500?
BTW, just checked Bentley and for 1975, 1976, 1977 all US models except 1977 California is 2 deg ATDC
R
recordsj
From the Haynes manual it says the following for igition timing:
1500, except USA: 10deg BTDC @ 680 RPM
1500, '75-78, USA: 2deg ATDC @ 800 RPM
1500, '78 and on, USA & Canada: 10deg BTDC @ 800 rpm
1500, '78 and on, California: 2deg ATDC @ 800 rpm
bigjones
Hi there,
I have a 1500, Pertronix and ZS carb.
The only time I had a knock it was the rod bearings.
They can be replaced from under the car - messy and claustrophobic but I would do it again. Probably best to also replace main bearing while you are there.
I use 87 gas (the cheapest) with no problem.
Cheers,
Adrian
Jim_Gruber
Didn'rt read that this was a 1500. With Bugsy a '68 Sprite with 66 vintage 1098 anything less than Sunoco 240 = dieseling on shutdown.
Morris
If you are getting "knocking" at idle, it seems unlikely that the noise you are hearing is spark related. Spark knock almost always occurs when the engine is under load.
If you can recreate the noise in your driveway, I would probe around with a stethoscope (a piece of vacuum tube in the ear works if you don't have a stethoscope) and isolate the source of the noise.
Given the 1500's reputation, it's very likely you have worn rod bearings or a dropped thrust washer.
R
recordsj
timing set at idle.
vacuum advance is connected and working.
the ping/knock is not noticable under load (like going up a decent hill in 4th), but noticable at idle and at <2000 rpms
JPSmit
Crankshaft - The weak point of 1500's is the thrust bearings that have an annoying habit of dropping out.
In the attached diagram, it is actually mislabeled as a "key" you are looking for the piece labeled #23 near the flywheel - it is "C" shaped
tosoutherncars
J, here's how you can check...
With a crowbar or similar, push backward on your main pulley (#24 above) to make sure it's fully back. Then, while watching it closely (or even better, with a dial indicator zeroed against it) have someone depress the clutch fully. If your thrust washer has worn or fallen out, it will allow the whole crank to 'walk' forward, and you will see movement at the pulley end. Really, any movement is too much - I think endfloat is supposed to be 0.001-0.003 or something, hopefully someone will correct me. Excess movement throws everything offline, causing strange noises, problems with main & rod bearings, and (eventually) engine failure.
Hopefully your problem is something less serious... but as mentioned above, the thrust washer and rod bearings can all be replaced with the engine in the car. Messy, but doable in the driveway. (Did mine a few weeks ago.)
-Duncan
R
recordsj
can you give me some basic instruction on how replace the rod bearings and main bearing with the engine still in the car? Would it be quicker (maybe at least easier) to remove the engine?
Morris
I respectfully disagree. Mains CAN be done with the engine in the car. But it is probably easier to pull the motor. At the least it's 6 one half a dozen the other.
The only real problem with pulling the motor is it could unearth or create other problems. And there are always the dreaded might as wells. Ask Tony about those. 6 months ago he pulled the motor in his '62 to replace the clutch and now he has a (almost) completely restored car.
R
recordsj
when the clutch pedal is pressed the crankshaft pulley moves forward, is this what I am supposed to be looking for if there are issues with the thrust washer and rod bearing?
how long did it take you to replace the rod bearings and thrust washers while the engine was still in the car?
EMGEBE TAT TAT TAT TAT TAT [engine knock?] MG 13
X Engine knock MG 5
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
