General Tech Engine Misses Only at 2200 rpm
KVH
KVH
My recently rebuilt TR4A has been running great. I have a new coil, new distributor, points, carbs--near everything. Over the past two weeks, however, a strange thing started happening. The engine misses rather badly at 2200 rpms. It's fine lower and higher. Regardless of which gear I'm in, the engine misses at 2200 rpms until I go slower or faster. On some occasions there is no missing at 2200 rpms, but most of the time there is missing at that point.
I don't know enough about coils or condensers to say they are likely culprits, and I can't imagine the issue is plug wires or plugs. I'll check the point gap assuming that's a possibility, but that also seems unlikely.
I hope it has nothing to do with vibration or balance, as that would seem to be a rabbit hole. I also don't see how timing could be implicated. I checked that after rebuild and I was good on that score.
Any thoughts out there?
Popeye
Bronze
I’m grasping at straws here - smarter folks will chime in: could your distributor advance be “sticking”? Below 2200 rpm it runs ok without, and some point above 2200 the vacuum is strong enough to overcome the resistance?
KVH
KVH
I’m using a Moss “Race” distributor that I believe has a limited advance. I'm uncertain whether that could be a part of the problem.
KVH
KVH
That sounds promising. I’ll pull the filters and take a look. Amazingly (or not) my new SUs really required a lot of polishing and careful fastening to avoid sticking on first instal.
sp53
I take out the brass piston filler plugs when doing a drop test. Does your racing distributor have the micro adjust for fine tuning the timing? I have seen coils that miss at a specific spot
steve
poolboy
You think it's the coil ?
Then here's the test.
Sarastro
That test in the Moss video is largely useless. You often can get a good spark in air, but not in the high pressure of the cylinder where the breakdown field is much higher. Furthermore, it's normally not possible to come up with a test that identifies a bad coil, as the coil usually seems fine at low voltages but arcs internally, or has some other problem, that shows up only at high voltages. Finally, if you try this, KEEP YOUR HANDS OFF THE METAL PARTS! There will be 150-250V on the primary. The guy in the video, who seemed to be touching the alligator clip, didn't get the shock of his life, only because he wasn't touching the cylinder head simultaneously.
The only definitive way to test a coil is by direct replacement with a known good unit.
That said, I doubt it's the coil. I agree that it's something like the carb piston or maybe the advance mechanism, which could malfunction at a specific speed. If the problem occurred at 2200 RPM and higher, the coil would be somewhat more likely.
PAUL161
Over the years I've had spark plugs that miss-fired under compression. Just saying. PJ
KVH
KVH
I’m really only misfiring at 2200. I’m going to check those carb pistons first. Then, I have a new coil I’ll try. I’ll report back. I’ll get this figured out. And I’ll check the plugs while I’m at it.
KVH
KVH
Following up, I removed and inspected my HS6 SU carbs and found that the piston in the rear carb was sticking in the housing. The carbs are new, so I was quite surprised. It seems that the manufacturing was a bit "off," to say the least. I had to rub and polish the inside of the housing. About ten times, each time noting where the abrasions were occurring. I finally got it. Piston moves freely up and down. I wonder if the heat from operating over the past few months caused some expansion or warping of the metal. Whatever the case, I'm no longer sputtering at 2200 rpms. The call that the issue was probably the "carbs" sure seems right on. I'm now running smooth. Great again. Such fun cars.
7 Engine misses under load Triumph 18
T TR engine misses badly Triumph 11
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
