TR2/3/3A Por-15 in engine block?
tinman58
Getting the block and head back from the machine shop tomorrow. Just wondering if there is anything that I can encapsulate the crud that won’t scrape off the walls Of the block.
tinman58
tinman58
Just to clarify, the water jacket is what I think I meant.
Hamish Racing
What have you had done. As I would expect it to be clean. Certainly if any work involved liner removal.
if it comes back clean I wouldn’t use anything as paint can detach and start blocking things like radiators and the painted surface can reduce heat transfer.
just use a good anti-freeze mix with a good rust inhibitor and change it every couple of years. If you don’t want an anti freeze use a house wet heating system inhibitor.
RGK
Multi-Purpose Glyptal® Red Enamel seals uneven surfaces in engine castings to improve oil circulation
  • Acid- and oil-resistant
  • Also resists moisture, heat dust, salt spray
  • Anti-corrosion protection
Glyptal 1201 seals the rough interior castings of engine blocks to help prevent engine damage. Sealing the tiny pores left in metal after bead blasting leaves the engine block interior smooth and clean, and that helps keep oil clean and flowing freely.
mctriumph
I would have been VERY miffed to get a block back that had any rust or crud left here.
Wire brush /naval jelly don't paint it!!! Just clean it. NO paint will stay on here!
Mad dog
charlie74
I thought about putting that glyptal on my block interior when I redid my engine. Once I had opened the engine up after it had sat with no oil in it for weeks and saw how much residual oil there was everywhere I decided not to bother. I recall reading that the preparation involved was very specific and my reasoning for not doing it was that if I didn’t get it absolutely right then I’d have it flaking off inside the engine possibly requiring another rebuild…
As said above, when it gets home from the machine shop clean clean clean it and then spray it with WD-40 or another preservative and it should be fine.
Jim_Stevens
On the outside of the engine, as I soda blasted the outer layer of dirt and grime, I did discover lo and behold the orange 3 on the side! That was heartwarming…
mctriumph
Not generally known , but paint is NOT water proof. There are marine specific paints that work well
under water , and epoxy's could be effective if the metal were cleaned enough. But most paints
will only last a few weeks when submerged , then flake off. IMHO this is where, clean it and trust in the
corrosion inhibitors in the antifreeze.
Mad dog
tinman58
tinman58
Mad dog!
got it no paint I trust your judgement!
Sarastro
Get a set of small rotary wire brushes that fit a 1/4" drill and an extension. They will take of any crud in the water jacket worth worrying about. I see no advantage to any kind of coating or paint inside the block, and lots of disadvantages.
bobhustead
A possible reason besides flaking of coatings is that the metal straight to coolant contact likely creates the best heat transfer.
CJD
In our racing engines we would polish and then paint all the internal surfaces exposed to oil. The idea was to allow the oil to get back to the sump quickly. We never considered painting the water jacket. Paint acts like an insulator, which is the opposite of what you want in the cooling jackets. If you are worried about debris flaking off, I would recommend you spend more time scraping and brushing the block clean. You should have no doubts about cleanliness before you assemble an engine.
Oh...rustoleum was our paint, and it was recommended by Chevy Performance at GM.
BOBBYR Por-15 engine paint Austin Healey 7
S TR2/3/3A used POR 15 for like a base primmer Triumph 8
S TR2/3/3A por 15 Triumph 13
W TR4/4A Por 15 Triumph 6
J POR-15 where to stop??? Spridgets 30
DNK Por 15 & Sound Proofing Triumph 9
H POR-15 is BAD use Zero-Rust instead Triumph 60
pjsmetana POR-15 & brush marks? Spray Version? Triumph 26
Skip_Shervington POR-15 use on interior floor pans Restoration & Tools 20
R POR-15 alternative Triumph 25
Don_R POR-15 vs Eastwood Encapsulator Triumph 19
M Coil Springs/Por 15 Spridgets 13
beaulieu POR 15 between door skin + door shell expanding Restoration & Tools 6
2wrench Exchange POR-15 war stories Triumph 25
N Will POR-15 sandblast off? Triumph 12
mrv8q TR6 Pre-Por-15 TR6 Triumph 6
beaulieu What really is POR 15 ? Restoration & Tools 36
Rob_P POR-15 MG 5
KVH Help with Waxoyl and POR 15 Triumph 8
KVH Question About POR 15 Triumph 5
Bret Bret’s Por Sha Follies. Other Cars 13
mgbmedic POR-15 question MG 8
C Is POR-15 any good ? Austin Healey 25
EinsteinsDad Painting parts: POR-15 or something else... MG 3
jaybird Prepping gas tank for POR MG 22
jlaird My POR catalog came in the mail today. Spridgets 7
Stewart How much por 15 MG 8
H POR 15 Restoration & Tools 5
regularman POR 15 Restoration & Tools 3
R POR 15 fueltank Spridgets 8
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
