knock off
wally stokes
I got my car out of storage and was taking the front wheel off and the knock off was really hard to get off I had to hit it 20 to30 times to get it loose. the knock offs and wheels were new last year. When i got the knock off free this black powder was on the threads. is this common
John Loftus
Wally,
If you put grease or better yet, anti-seize paste on the threads and splines each year they will remove easily and last a lot longer.
Cheers,
John
Keoke
Wally, Johns response is true.However, I would recommend Coppa Slip on the threads and splines.This is one of the best anti seize compounds I have found. It is available from British Wire Wheel.--FWIW---Keoke
Sorry I mised the fact you are in CA the material is availble from Molly Slip there,
dklawson
I have used anti-seize on my TR's splines, threads, and the nose taper of the wheels for years. It makes a big difference. I also use anti-seize on the threads of regular wheel studs. I had an entire rim stick to a brake drum while living in NY and have used anti-seize ever since.
W
wally stokes
thanks for the info but i still do not understand what the black powder was. There was about a table spoon and was black like grafite
Keoke
[ QUOTE ]
[/ QUOTE ]
Well Wally some of the old timers did put "grafite" in grease to treat the splines.Grease may have just dried up.---Keoke
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
T Knock-Off Spinners Austin Healey 43
TomMull Knock Off Tool Restoration & Tools 6
CJD TR2/3/3A Knock Off Differences Triumph 13
Feathers Knock off wheels for sp250 Other British Cars 6
H General TR Triumph Script Knock-Off Hub Cap Triumph 6
Healey Nut Knock off removal Austin Healey 3
J knock, off tools Jaguar 6
RickB NFI - knock off tool $10 Spridgets 2
Westfield_XI Help, I need a knock off wrench Spridgets 17
britndablood Needed 1 two eared knock off RH side 12 tpi Austin Healey 3
L New Knock-off Spinners Austin Healey 21
Brosky TR6 Custome TR6 Knock-Off wheels....OK.... Triumph 1
T Looking for used set of Knock off minilites Spridgets 4
kodanja Knock it off? Triumph 13
kodanja Knock off grease? Triumph 14
jaybird I need to bribe someone or knock someone off MG 22
M Knock off's......or..... Fall off's MG 6
John Loftus Knock off lettering Austin Healey 14
G Lead Head Knock-off Hammer Austin Healey 10
S Knock-Off Hub bearings - Can they be removed? Jaguar 1
S Converting from a knock-off to a 5-bolt hub. Jaguar 1
6 Knock off minilites MG 3
Michael Oritt Safety-wiring knock-offs Austin Healey 24
R Knock Rover / Land Rover 1
S TR2/3/3A What a sad day. There is a knock at the door. Triumph 7
HighAltitudeTR3 TR2/3/3A Valve Knock Question Triumph 28
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Knock knock... what's this? Triumph 100
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
steveg Has anyone used a knock sensor? Austin Healey 0
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
S Knock in Transmission/Gearbox Austin Healey 4
S Eared knock-offs - how tight? Austin Healey 19
CJD TR2/3/3A Coarse Vrs. Fine Knock Offs Triumph 5
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
V Panasport Fake Knock Offs Triumph 8
Got_All_4 Wedge Searching for knock offs for TR7 wheels Triumph 2
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
UmmYeahOk Knock Offs - Whats the deal? Triumph 28
prb51 Pinking, Knock, Plinking etc. Triumph 6
R engine knock/ping, retard ignition doesn't help Spridgets 49
DNK KNOCK- KNOCK-KNOCK Triumph 59
MadRiver Octagonal safety knock-offs MG 7
N Starting out in 1st gear knock or clunk Triumph 20
C Wire Knock-offs Triumph 9
