Knock in Transmission/Gearbox
SideShifter Tri-Carb
I pulled the tri-carb out of winter storage today to warm up my spirits, and I was greeted with a new sound in the gearbox. I'm fairly certain it is in the main body, because I removed the tunnel and could feel a bit of impact on the right side. The noise goes away with the clutch engaged or when in gear. I have a spare box ready to go in, just wanting to know what the wise men here think the knock is coming from. I always expected that the bearings were toast when I drove it last year.
Just thought to check the oil and it is low (as in not on the stick). I am going out to get some 30 wt. and see if it goes away.
S
Put in a quart of oil and that took it to the 1/4 level between fill and full. It was still there, but much less. I plan to pull the gearbox tomorrow and see what I see. Any suggestions to what the cause is?
My bet would be on the needle rollers where the mainshaft and the input shaft come together, particularly since you were low on oil and seem to have been that way before the car was put away for the winter. I had the same sort of thing with an Alpine years ago and that was the cause and result.
S
Got the spare in last night, and I must say, that I don't care to do that again. I haven't checked to make sure the knock was entirely gone because I did recognize that the dowel bolts that align the transmission were not present. Would anyone happen to have a pair so i can wrap this job up?
TimK
Try British Car Specialists.
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
T Knock-Off Spinners Austin Healey 43
Michael Oritt Safety-wiring knock-offs Austin Healey 24
TomMull Knock Off Tool Restoration & Tools 6
R Knock Rover / Land Rover 1
S TR2/3/3A What a sad day. There is a knock at the door. Triumph 7
HighAltitudeTR3 TR2/3/3A Valve Knock Question Triumph 28
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Knock knock... what's this? Triumph 100
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
CJD TR2/3/3A Knock Off Differences Triumph 13
steveg Has anyone used a knock sensor? Austin Healey 0
Feathers Knock off wheels for sp250 Other British Cars 6
S Eared knock-offs - how tight? Austin Healey 19
H General TR Triumph Script Knock-Off Hub Cap Triumph 6
CJD TR2/3/3A Coarse Vrs. Fine Knock Offs Triumph 5
Healey Nut Knock off removal Austin Healey 3
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
J knock, off tools Jaguar 6
V Panasport Fake Knock Offs Triumph 8
RickB NFI - knock off tool $10 Spridgets 2
Westfield_XI Help, I need a knock off wrench Spridgets 17
Got_All_4 Wedge Searching for knock offs for TR7 wheels Triumph 2
britndablood Needed 1 two eared knock off RH side 12 tpi Austin Healey 3
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
L New Knock-off Spinners Austin Healey 21
Brosky TR6 Custome TR6 Knock-Off wheels....OK.... Triumph 1
UmmYeahOk Knock Offs - Whats the deal? Triumph 28
T Looking for used set of Knock off minilites Spridgets 4
prb51 Pinking, Knock, Plinking etc. Triumph 6
R engine knock/ping, retard ignition doesn't help Spridgets 49
DNK KNOCK- KNOCK-KNOCK Triumph 59
kodanja Knock it off? Triumph 13
MadRiver Octagonal safety knock-offs MG 7
N Starting out in 1st gear knock or clunk Triumph 20
kodanja Knock off grease? Triumph 14
C Wire Knock-offs Triumph 9
jaybird I need to bribe someone or knock someone off MG 22
M Knock off's......or..... Fall off's MG 6
John Loftus Knock off lettering Austin Healey 14
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
TR4 Wire Wheel Knock Offs???? Triumph 13
EMGEBE TAT TAT TAT TAT TAT [engine knock?] MG 13
W knock off Austin Healey 7
R Best price for Minilite Knock-offs? MG 8
