Knock it off?
kodanja
Can someone tell me how tight Dayton knock off spinners really have to be? Is there a recomended torque?
I have the 72 spoke set & sometimes I think maybe I'm hitting the on too tight... /bcforum/images/%%GRAEMLIN_URL%%/nonono.gif
Brosky
When you get a big brass hammer that has a torque readout on it, let me know.
DNK
Now how long before we see a Photoshop of that?
kodanja
kodanja
is it possible to wreck the threads by hitting it too hard?
kodanja
kodanja
LastDeadLast said:
I have the two eared nuts on mine. I purchased the big long wrench thingy that Moss sells... It's nice. I torque it down pretty tight.
Great, I think I'll purchase one of those then, Plus it's alot less wear and tear on the hub.
TR3driver
Great Pumpkin - R.I.P
Nah, you'll wreck the ears on the knockoff first.
When I got my 59 TR3A, the splines were ruined and the DPO had reefed down on the knockoffs until the friction in the tapers was enough to keep the wheels from turning on the adapters. I had a terrible time getting them off, but the threads were fine.
Geo Hahn
I use a 1"x1" 10" length of oak against the ear of the knock-off and hit that with a 3 lb. dead-blow hammer. All I do is snug it up real good.
It's my understanding that they will get tighter as you drive due to the flexing of the wheel. Indeed that is why they are handed differently left & right... mount them on the wrong side (or tow the car backwards) and they will loosen as you drive.
kodanja
kodanja
Great info thanx!
(( not a murderous attack with a heavy hammer ))
Harry_Ward
On my 3 I tighten the knock off as tight as possible by hand. Then while the car is still jacked up in the air I will hold the tire with my left hand and hit the knock off easily with just the weight of the hammer (but not lean in to it) till the knock-off stops spinning or the tire moves against the hammer. Once the car is on the ground I will hit it again once or twice with just the weight of the hammer and not lean in to it. I will then drive it a couple of miles (usually to the first stop of the drive) and then whack it again with one or two easy swings just using the weight of the hammer. I have heard it is bad news to fully tighten the knock off to the hub with the car on the ground static.
A whole lotta whackin goin on! /bcforum/images/%%GRAEMLIN_URL%%/hammer.gif
kodanja
kodanja
Ill have to try that method in the air.
Thanx
Harry
Deleted member 451
I read the VTR paper a few years ago and decided to test it out. I live on a circle with no stop signs about 3/4 mile long. I left the back left wheel hand tight and drove it around the circle 5 times. When I stoped the wheel was as tight as the others. Now I use a soft lead hammer and just give them a couple of taps when I put them on. I will say that I did the test with new wheels and hubs so I'm not sure I would trust ones that have been overtightened in the past.
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
T Knock-Off Spinners Austin Healey 43
TomMull Knock Off Tool Restoration & Tools 6
CJD TR2/3/3A Knock Off Differences Triumph 13
Feathers Knock off wheels for sp250 Other British Cars 6
H General TR Triumph Script Knock-Off Hub Cap Triumph 6
Healey Nut Knock off removal Austin Healey 3
J knock, off tools Jaguar 6
RickB NFI - knock off tool $10 Spridgets 2
Westfield_XI Help, I need a knock off wrench Spridgets 17
britndablood Needed 1 two eared knock off RH side 12 tpi Austin Healey 3
L New Knock-off Spinners Austin Healey 21
Brosky TR6 Custome TR6 Knock-Off wheels....OK.... Triumph 1
T Looking for used set of Knock off minilites Spridgets 4
kodanja Knock off grease? Triumph 14
jaybird I need to bribe someone or knock someone off MG 22
M Knock off's......or..... Fall off's MG 6
John Loftus Knock off lettering Austin Healey 14
W knock off Austin Healey 7
G Lead Head Knock-off Hammer Austin Healey 10
S Knock-Off Hub bearings - Can they be removed? Jaguar 1
S Converting from a knock-off to a 5-bolt hub. Jaguar 1
6 Knock off minilites MG 3
Michael Oritt Safety-wiring knock-offs Austin Healey 24
R Knock Rover / Land Rover 1
S TR2/3/3A What a sad day. There is a knock at the door. Triumph 7
HighAltitudeTR3 TR2/3/3A Valve Knock Question Triumph 28
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Knock knock... what's this? Triumph 100
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
steveg Has anyone used a knock sensor? Austin Healey 0
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
S Knock in Transmission/Gearbox Austin Healey 4
S Eared knock-offs - how tight? Austin Healey 19
CJD TR2/3/3A Coarse Vrs. Fine Knock Offs Triumph 5
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
V Panasport Fake Knock Offs Triumph 8
Got_All_4 Wedge Searching for knock offs for TR7 wheels Triumph 2
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
UmmYeahOk Knock Offs - Whats the deal? Triumph 28
prb51 Pinking, Knock, Plinking etc. Triumph 6
R engine knock/ping, retard ignition doesn't help Spridgets 49
DNK KNOCK- KNOCK-KNOCK Triumph 59
MadRiver Octagonal safety knock-offs MG 7
N Starting out in 1st gear knock or clunk Triumph 20
C Wire Knock-offs Triumph 9
