knock, off tools
jessebogan
Which knockoffs do you have? The safety knockoffs that take the bronze tool? (Your car came with them) Or are you looking for a GOOD tool for the eared type?
J
jet_jockey
Thanks for the reply Jesse, I have the two eared type. I haved mated two woodend knockoffs with screws and an now going to fabricate a metal sleave and "johnson-bar" attachment to the wooden tools in order to gain leverage.
jet jockey and new XKE owner
jessebogan
I have a very few really well made ones available. I had a guy I know (custom furniture maker in New Orleans) make me 10 out of maple sandwiching an inner core of softer mahogany. I use the test unit a lot, and beat the you know what out of it (5 years so far with no breakage) I have a couple left, mostly I supply them to customers. Not cheap however. I had been hoping to sell a buch to justify having him take them to a CNC woodworking shop to cut the cost down to something approaching reasonable. These were hand built, and therefore expensive. Seemed like a good idea at the time....
why
I bought an all metal one many years ago with a long handle so nothing to hammer, the fitting over the two-eared knock-off cut grooves in the knock-off, do not buy that one.
Jay, '67S1
J
jet_jockey
Hello Jesse and Jay,
Thank you both for the input to a knock off tool. It ended up I purchased two wooden ones, sandwiched them together, inserted metal plates at the points of contact and then made a long metal lever to apply leverage. Finally got them off and re-assembeled with "never-sieze".
Now the hot start issue??
Greg in Montana
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
T Knock-Off Spinners Austin Healey 43
TomMull Knock Off Tool Restoration & Tools 6
CJD TR2/3/3A Knock Off Differences Triumph 13
Feathers Knock off wheels for sp250 Other British Cars 6
H General TR Triumph Script Knock-Off Hub Cap Triumph 6
Healey Nut Knock off removal Austin Healey 3
RickB NFI - knock off tool $10 Spridgets 2
Westfield_XI Help, I need a knock off wrench Spridgets 17
britndablood Needed 1 two eared knock off RH side 12 tpi Austin Healey 3
L New Knock-off Spinners Austin Healey 21
Brosky TR6 Custome TR6 Knock-Off wheels....OK.... Triumph 1
T Looking for used set of Knock off minilites Spridgets 4
kodanja Knock it off? Triumph 13
kodanja Knock off grease? Triumph 14
jaybird I need to bribe someone or knock someone off MG 22
M Knock off's......or..... Fall off's MG 6
John Loftus Knock off lettering Austin Healey 14
W knock off Austin Healey 7
G Lead Head Knock-off Hammer Austin Healey 10
S Knock-Off Hub bearings - Can they be removed? Jaguar 1
S Converting from a knock-off to a 5-bolt hub. Jaguar 1
6 Knock off minilites MG 3
Michael Oritt Safety-wiring knock-offs Austin Healey 24
R Knock Rover / Land Rover 1
S TR2/3/3A What a sad day. There is a knock at the door. Triumph 7
HighAltitudeTR3 TR2/3/3A Valve Knock Question Triumph 28
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Knock knock... what's this? Triumph 100
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
steveg Has anyone used a knock sensor? Austin Healey 0
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
S Knock in Transmission/Gearbox Austin Healey 4
S Eared knock-offs - how tight? Austin Healey 19
CJD TR2/3/3A Coarse Vrs. Fine Knock Offs Triumph 5
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
V Panasport Fake Knock Offs Triumph 8
Got_All_4 Wedge Searching for knock offs for TR7 wheels Triumph 2
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
UmmYeahOk Knock Offs - Whats the deal? Triumph 28
prb51 Pinking, Knock, Plinking etc. Triumph 6
R engine knock/ping, retard ignition doesn't help Spridgets 49
DNK KNOCK- KNOCK-KNOCK Triumph 59
MadRiver Octagonal safety knock-offs MG 7
N Starting out in 1st gear knock or clunk Triumph 20
C Wire Knock-offs Triumph 9
