TR2/3/3A Transmission / drive shaft knock ??
Big D
Recently my 1960 TR3A has been making a strange noise from the drive system. In 1st OR reverse there is a sound almost like something is striking against one of the drive shaft bolts. It's not a horrible sound, just a constant 'tick' that changes in step with the engine RPM. The curious thing is that this does NOT happen when in the higher gears.
If something were interfering with the drive-shaft rotation the sound would happen in ALL gears, no ??
Any ideas out there ??
Thanks in advance,
Don
Merlin63Tr4
Sounds like a broken gear tooth.
If it was something striking the drive shaft the noise would happen in all gears.
M.
CJD
It's like spinning the roulette wheel every time you run it. Sonner or later that tooth will get picked up and get caught between other gears...shelling the entire tranny. Best to take care of it while it's just one gear and maybe a couple bearings.
Tried to post a pic, but I'm at the kids high school, and they seem to have photbucket locked out here. There are 2 possible gears that it could be...
If it is relatively high frequency, like several clicks per revolution, then it's the "cluster gear...
https://www.ebay.com/itm/Triumph-TR...m1a08173046:m:mdgOlfsFvoEtwYHxDqvD2hg&vxp=mtr
If it is lower frequency, then it's the 1st/reverse slider gear...
https://www.ebay.com/itm/TRIUMPH-TR...ash=item5b1bb2a220:g:wJ0AAOSw~gRV4JHD&vxp=mtr
Merlin63Tr4
Don,
John beat me in posting a reply.
Yes, looks like it is time to pull the trans.
At least, all the good driving weather is pretty much over out where you are.
M.
B
Big D
Don,
M.
John / Merlin,
Thank you both for your wisdom and advice. My plan is to remove the tunnel cover and disconnect the drive shaft. If the noise (tick) is still there, it's the tranny for sure. By the way John, the tick is quite slow so it may indeed be the slider gear.
I've done some research and it looks like replacing this gear would be a MAJOR project. If it is the tranny, I'm going on the hunt for a rebuilt gearbox.
Thanks again guys,
Don
bnw
I had that noise once. Back in 1970 I was waiting for my wife to return from shopping. I had lots of time so I pulled the shifter cover from the gear box to take a look. Couldn't see anything so I started it up. That stinky gear oil started flying everywhere so I grabbed a T shirt from the rear bench to cover the opening. The shirt got sucked in instantly and killed the engine. I had to tow the car to a Ford dealership where there was a tech who moonlighted Triumph gear box repairs. He replaced the gearbox with a TR4 unit for about $125 I recall. BTW, it was a tooth on the cluster gear. To this day, no matter what standard trans I'm driving, I always drop back to 2nd before I engage 1st or reverse.
Merlin63Tr4
Here's my "war" story,
A couple of years ago
on a cold rainy day, I lost the needle bearings in the cluster gear/layshaft some 20 miles from home .
It is really amazing how much noise that failure causes. Almost like metal shot being fed thru a meat grinder.
Somehow I made it home. The amount of shrapnel that came out with the gear oil when I drained the transmission was mind-blowing…..
Of course the shrapnel circulated thru the OD and that had to be replaced too....
:censored:
M.
sp53
These transmissions are not difficult to rebuild and there is an excellent chapter in the Haynes manual on how to do without any specialty tools. If the trans is OD that is more complicated, and I have not done one. John posted some excellent pictures on that. In addition there are People who specialize in rebuilding these and their prices seem reasonable. I think you should give it a go with the help on the form, and you will be pleasantly surprised with the results. Many places only want a core and I bet they would take a basket case as a core. Nothing to lose and knowledge to gain.
TR-3rg
Hi,
I rebuilt my 3a gearbox with parts from TRF. I drove it for a week and broke a tooth off it by jamming it in 1st gear at a stop light. I followed the instructions in VTR without issue. About a year later I picked up a TR-4 box and rebuilt it. This time I bought the kit from Quantum Mechanics and followed the instruction in Buckeye Triumph. In both cases, I replaced the springs and ball detents in the 1-2, 3-4 shifter hub.
Personally, I would find a TR-4 or later gearbox and use that. A nice TR-4 gearbox is a lot of fun to drive. The next gearshift is a click away. They are that smooth!
Roy
mallard
I'm not the best at transmissions, but can't you remove the trans cover, drain the oil, and inspect all the gears before you remove the whole thing?
CJD
1st /reverse, yes. The cluster gear is buried, though. Maybe if you are persistent with a mirror or one of those fancy snake cameras they have at autozone these days.
TexasKnucklehead
I broke a tooth off 1st twice. Both times required a complete disassemble before I could see the broken tooth -as John said, it's buried. The second time I broke off a tooth, I didn't want to deal with it but wanted to drive the car. I drained the oil but the broken tooth didn't fall out. So I dragged a strong magnet across the underside of the case until I managed to drag the broken tooth to the hole, and fished it out. Then I put the used oil back in, and drove the car (avoiding 1st gear) for another few months until I had time to rebuild it properly. The real danger is having that broken tooth find it's way into a spot where it can very quickly make things much worse. Aside from constantly forgetting to start in 2nd, it worked fine. It only clicked when I had it in 1st -reverse may have made a click too, but I generally try to drive forward. :smile:
B Transmission rear bush for drive shaft yoke - no joke! Spridgets 2
P Drive shaft won't come out of the transmission Spridgets 6
Zitch TR4/4A OD Addition to a Non Over-Drive Transmission - my attempt Triumph 11
S Transmission Speedometer Drive Triumph 4
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
S MGB Transmission cross member re-install MG 14
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
WHT BJ8 Transmission Installation Austin Healey 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T How to ship transmission from Canada to Rivergate in Tennesee? Spridgets 8
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
A TR6 Installing differential and transmission Triumph 10
PAUL161 T-Series 5 Speed Transmission MG 85
