solid wheel knock-offs , do they exhist ?
beaulieu
I would like to put some knock-off wheels on a special I am building,
But I do not want wire wheels ,
So are there any British cars that used solid rims with a knock-off hub ?
prefer 15 - 16 inch rims
thanks for your help
Steve_S
Twin Cam and Mark II Deluxe MGAs used knock-off pressed steel wheels. However they are extremely difficult to find, and are very expensive if you do manage to locate a set. I seem to recall a single wheel in average condition selling on eBay recently for around $400. A full set of nice wheels would easily fetch over $1K.
R
Randi
But Steve go get chromed out "fly" wheels with independent spinners and spend $8,000. Twin cam wheels are cheap-it"s finding good ones that's hard! Sorry could help myself.....when I'm next to a Lexus SUV and can see myself & the car in those shiny chrome 18's (?) it's kind of scary!!!!!!!Randi /ubbthreads/images/graemlins/jester.gif /ubbthreads/images/graemlins/jester.gif I'm trying to forget I'm Old & just don't understand why that old lady is in my car!!!!!!!!!!!!!!!!
beaulieu
beaulieu
minilites are OK, but I need the look of early period correct rims
Steve_S
LOL @ Randi! /ubbthreads/images/graemlins/lol.gif
I also just remembered that the twin-cam wheels were not splined. They use a knock-off to secure to the car but not splines. I heard rumor that one person has successfully mated splines to a steel MGA-style wheel by welding a wire wheel hub into the wheel and adding support gussets.
piman
Hello Beaulieu,
what period are you refering to?, the Minilite style is 60's, if you want earlier and 15" look for jaguar (Dunlop) wheels. I believe that they are curently being re-manufactured but they are expensive. The style is similar to the MGA Twin Cam, or look at the Jaguar 'D' Type racing car.
Alec
beaulieu
beaulieu
I am looking for a steel wheel not a cast Minilite style wheel, I found a picture of the MGA TWINCAM wheels, something like that would do,
Any idea who sells the Jag wheel ? or a picture of one ?
just the inner stamping would be OK, I can get the outer rim here
thanks
William
The Jaguar D-Type wheels by Dunlop featured a spun aluminum center mated to a steel rim (or was it the other way round?). They are still being manufactured, since you see them on the better D-type replicas. These are peg-drive wheels, meaning they use a threaded hub to secure the wheel to the hub, but pegs to provide drive (if you look at a Dunlop wheel, it looks like it has five lug nuts). The nice thing is, no splines to wear out.
An even rarer type would be the Rudge knock-off disc wheels as found on certain Mercedes racing cars of the fifties, and were optional on the SL. These were a true splined knock off with ally rims. I have no idea if they're still being made, but knowing Mercedes, they probably are, at a price.
If you know of a wheel maker, a set of vented disc wheels in the appropriate size could conceiveably be fitted with splined centers.
-William
GregW
I've been trying to re-find this thread for days! Check out Dave Bean Engineering . They’ve got some Lotus wheels for about $200 each. The rims are 13” but they might come bigger, worth a call.
LLAngus
I just looked into the Moss catalog and found the cast wheels (MGB catalog). They may have a source for steel wheels. Phone them and find out. There is a web site featuring steel wheels (KO) for Corvettes. Maybe they have ones to fit.
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
C AUF214 solid state conversion question British Motor Corp 0
R Solid state SU Fuel Pump Austin Healey 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
BobbyD New OD Controller & Solid State Rheostat Triumph 0
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
coj Solid state turn and brake box Austin Healey 7
V Solid state fuel pump question Spridgets 2
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
M Solid state conversion of Lucas regulator Triumph 9
bighealeysource Noisy solid state fuel pump Austin Healey 15
T GT6 GT6+ - could be a solid car Triumph 22
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
BugEyeBear Nice Solid BugEye on eBay [not mine...] Spridgets 8
Morris Solid core wire Spridgets 6
vping Installing a Solid State Fuel Pump MG 7
J TR4/4A TR4A solid axle assembly Triumph 15
B solid looking project for someone Spridgets 7
B MOSS solid state fuel pump Spridgets 3
ronzet Flame Thrower solid state distributor for my A MG 12
B solid bronze TW Spridgets 1
vping Anyone use a solid state fuel pump? MG 35
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Westfield_XI Solid mounted Spridget transmission Spridgets 0
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
D E-type solid rack mounts? Jaguar 6
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
racing girl How Many Of You Use A Solid Neck/Shoulder Brace? Racing 3
M Solid color or 2 tone paint Austin Healey 8
Banjo TR4/4A Soon to be parting a TR4A solid axle Triumph 1
AUSMHLY Su Solid state fuel pump Austin Healey 26
T Solid Sway Bar bushing mounts Spridgets 2
3 Solid vs. poly vs. stock rack mounts. Triumph 10
R rusty but solid seat bottom Spridgets 4
Basil Seriously considering solid stainless cylinders Jaguar 9
