    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Solid core wire
Morris
Is it ever okay to use solid core wire (such as used in household applications) in a car? I want to make a few wiring upgrades involving relays and such, and using a solid core wire (that would be attached to the frame and exposed to no vibration) would make things real neat.
I guess that the answer is NO! But I wanted to ask just in case.
Is it OK? No. Wrong type of insulation, and solid wire would be too brittle for the vibration.
No, despite what you might think it won't carry as much current as multi strand wire of the same diameter and it's much more prone to vibration cracking. I know what you mean though, it would be easy to form a really neat wiring setup with this ridget wire, nice straight runs and gentle curves. Unfortunately it's not the best thing to use. Now if you just wanted to use it for support you could attach the other wires to it and wrap them together gaining the strength of the solid core to keep the harness from sagging.
Yes - to reattach your muffler to get it off the highway ad back to the shop :laugh:
OK I'm being silly I know
I used my spare fan belt last time that happened.
I wouldn't use it. Copper work hardens really easily, and that can happen even if you think you've tied it down well. It may not fit the connectors right. You might still get away with it, but these cars are unreliable enough without tempting fate.
NO don't use it, at all. Despite all of above temperature rating of insulation will not cope with heat inside bonet (hood) you need propper automotive wire, which will be stranded & rated at 120'C. Get a propper crimp tool while your at it. Most electrical problems are caused by bad crimps.
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
C AUF214 solid state conversion question British Motor Corp 0
R Solid state SU Fuel Pump Austin Healey 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
BobbyD New OD Controller & Solid State Rheostat Triumph 0
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
coj Solid state turn and brake box Austin Healey 7
V Solid state fuel pump question Spridgets 2
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
M Solid state conversion of Lucas regulator Triumph 9
bighealeysource Noisy solid state fuel pump Austin Healey 15
T GT6 GT6+ - could be a solid car Triumph 22
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
BugEyeBear Nice Solid BugEye on eBay [not mine...] Spridgets 8
vping Installing a Solid State Fuel Pump MG 7
J TR4/4A TR4A solid axle assembly Triumph 15
B solid looking project for someone Spridgets 7
B MOSS solid state fuel pump Spridgets 3
ronzet Flame Thrower solid state distributor for my A MG 12
B solid bronze TW Spridgets 1
vping Anyone use a solid state fuel pump? MG 35
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Westfield_XI Solid mounted Spridget transmission Spridgets 0
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
D E-type solid rack mounts? Jaguar 6
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
racing girl How Many Of You Use A Solid Neck/Shoulder Brace? Racing 3
M Solid color or 2 tone paint Austin Healey 8
Banjo TR4/4A Soon to be parting a TR4A solid axle Triumph 1
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
AUSMHLY Su Solid state fuel pump Austin Healey 26
T Solid Sway Bar bushing mounts Spridgets 2
3 Solid vs. poly vs. stock rack mounts. Triumph 10
R rusty but solid seat bottom Spridgets 4
Basil Seriously considering solid stainless cylinders Jaguar 9
