What is correct wire harness outer wrap
red57
It seems like most of the new wiring harnesses available are cloth wrapped but the 1960 BT7 I'm working on has wire harnesses wrapped in black vinyl tape.
I bought the car in 1987 and there was no evidence of prior restoration when I got it so I always assumed the wire harness was factory. I prefer a black vinyl wrapped harness because I can add new circuits like driving lights and wrap with vinyl tape and it all looks uniform - if I use the cloth wrapped harness, any added circuits will be obvious.
Does anybody know how to identify which type of outer covering for which years/models of car?
Thanks,
Dave
Keoke
HI:Dave
I have seen wire harnesses wrapped in cloth predominantly on original cars, additionally I have seen what I think are after market ones wrapped in blue vinyl
I have not seen replacement harnesses wrapped in black vinyl
Wrapping a harness in a non breathing outer cover will further reduce It's current carrying capability
BigGreen
Black Bicycle handlebar tape (cloth version) might be an option
red57
red57
Thanks for the replies. As I said, I bought the car in 1987 and it had a black vinyl wrapped harness that appeared to be factory.
Keoke, I haven't heard about capacity restrictions from vinyl wrapping (all the American cars of the 50s thru 70s I've had were vinyl wrapped). I actually figured cloth was a poor choice for road dirt and holding water along the bottom of the car??
BigGreen, The tape you are referring to, I think is what I used to know as friction tape and you are right, if I have a cloth wrapped harness then it would match better than typical PVC tape.
Steve, Finding cloth covered wiring isn't the problem. I'm more interested in why I have a car with vinyl and most suppliers only offer the cloth. The only supplier I have found
offering optional vinyl wrapped is SC Parts here:
https://www.scparts.co.uk/sc_en/bri...nd-dashboard/wiring-harness/harness-8690.html
The real question is did the factory use vinyl wrapped harnesses and, if so, when & on what models - heritage cert says nothing about this and I can't fined anything in Clausager's Original Austin-Healey.
I'm not going for concourse but have become curious.
Thanks,
Dave[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]
[/FONT]
Keoke
Well Dave Lucas Was doin the Engineering N he had some unique ideas---:highly_amused:
A more accurate reason is:
wire's current handling capability is determined on a individual wire basis in free space , consequently when we bundle , wrap in PVC, enclose in sleeving we alter its operating environment which lowers it's current carrying capability.
vette
I'm not sure it this pic came thru I was trying to enlarge it so you could read it. It is from Anderson & Moment and shows the woven fabric on the BT7 just as Steve's source says. Anderson & Moment says nothing about any distinction between cars and only discribes that the harness had black woven fabric with a yellow fine line cross hatch on it. It also says the rear harness was all black woven with no cross hatch.
red57
red57
Thank you vette. I think you have solved the mystery for me. Apparently a PO must have rewired the car sometime prior to 1987 - a lot can happen in 27 years..... I know it had been re-painted at least 3 times so who knows what else it had gone through.
Anyway, I will proceed with a cloth wrapped harness. I'm not going for concours, but I'm probably better off doing what the factory did in this case.
Thanks to all for the help.
Dave
steveg
The next page has a chart with color trace descriptions.
vette
Yes it does but I wasn't sure if the print would be large enough to read and it is mostly redundant to what was just said including the supplier that you linked to would surely show what was needed. Since I was trying to enlarge my other pic I didn't want to add to the size of my up load. But I think I got now.
Bye the way if it can be seen, this pic shows the harness as it should b strapped to the off side inner structure brace.
gladhill1937
All original 100's had fabric covered wiring except for the one from front to back along the chassis rail for the rear lights. It is vinyl wrapped for protection.
Years ago the only replacement wiring was vinyl wrapped. I think that might be what you have.
Deleted member 8987
Well.....Lucas Was doin the Engineering N he had some unique ideas---:highly_amused:
Yes, current handling capacity is determined by the wire size, shape, and composition. The real issue, however, is heat (something you generally don't have n non-Lucas 12V automotive systems). You bundle tightly, heat builds up, you start having issues with current handling.
NOT because they are bundled.
If so, all those 60-pair Key System phone lines would have burned up last century.
And, that's mostly AC...and we're DC.....tightly bundled never made a difference. However, if you are worried about Lucas heat and the possibility of smoke escaping, probably a wiring tray would be best, where one wire going up in a mushroom cloud won't affect the rest.
I used non-adhesive harness tape to wrap the wire for the rear lights (just couldn't leave the fabric exposed down there). Not sure if it's technically correct for a Healey, but it's period correct:
https://www.amazon.com/Factory-Electrical-Adhesive-Harness-Friction/dp/B06Y2KDQRN
Keoke
You bundle tightly, heat builds up, you start having issues with current handling.----YEP
RAC68
Hi Dave,
Although it is obvius that you can purchase a new harness, back in the '80s, I sent my original harnesses to have them rewrapped by (I believe) British Wiring with the original woven pattern (fabric). Since my harnesses were electrically in good condition but looked weathered, having the haranesses wrapped greatly improved its look and also retained the original bends making reinstallation much easier. Although I can't remember the price (and it would not be relevant if I could), I can tell you it was quite a bit less expensive then purchasing new harnesses.
It's an alternative you may want to consider,
Ray(64BJ8P1)
dcarlg
I replaced my BT7 wiring with a harness from Moss in 1980. It is wrapped with black vinyl tape.
And it was not exactly correct, but I made it work. Still does.
Good luck.
Douglas
dezand
Concur with RAC68, back in 1977 when I restored my 1960 BT7 I had the original harness recovered with the original fabric with the yellow tracer. Was done by a company called YNZ Yesterday's parts, which at the time was out of his home garage about a mile from where I was living. He subsequently opened a real shop and is still quite busy and has a nice website. If I recall he charged me $35 at that time. You can see some of the harness in this picture. He knew exactly what it needed when I showed it to him. He told that 22 year old kid (me) to take it home clean it thoroughly by removing all the fabric, cleaning the wires and then putting electrical tape every six inches to keep it together in the correct shape.
W TR2/3/3A Correct thickness for wire wheel spacers [3A]? Triumph 13
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
