TR6 Correct LED flasher relay
Gliderman8
Currently I have LED bulbs (1157) in the Front Left/Right turn signals and regular incandescent (1156) in the Rear Left/Right turn signals.
All turn signals work as they should. Tonight I replaced the rear turn signal bulbs with LED bulbs and turn signals do no flash.
Can someone recommend an electronic LED flasher unit that will work in my car? Make? Model number?
NutmegCT
SASSAMON
Not sure on the TR^ but the flasher circuit on the TR2-3 cars need a third contact for the dash indicator.
What is shown on Amazon and Moss are two contact units.
I have not tried one yet but my research has led me to the flasher EF33RL also available at Amazon and local car part stores.
Good luck with your turn signals may they blink brightly.
Roger
Tr4aJim
Elliot, I converted my TR4a turn signals (and brake lights) to LED bulbs, and used the Moss CEC electronic flasher (3 prong). I then had a problem where the stock turn signal indicator on the dash would continue to flash (for 10-15 seconds) after the signal was turned off. I have read on the various forums of others having this same issue.
As a test, (though Moss advises against doing this), I replaced the dash indicator bulb with an LED after market bulb that I found at my FLAPS. This fixed the problem to the extent that the indicator then only flashed one or two extra times after turning off the indicator.
I lived with it like that for awhile until I read of someone solving this problem using a “Flosser” electronic flasher. I found that British Parts Northwest sold them. I swapped one in and the problem went away. The only obvious difference between the CEC and Flosser units is that the CEC has a separate ground wire, while the Flosser does not.
Good luck,
Jim
Gliderman8
Gliderman8
Thanks guys. I just ordered the EF32RL. Hopefully that will work including the indicator light which by the way already has an LED bulb and is working fine.
Gliderman8
Gliderman8
The EF32RL arrived today. I just installed it and problem solved!
Jim- I can tell you that after the turn signal ends the indicator on my dash flashes maybe two times; I do not find it at all annoying since it only lasts 1-2 seconds. By the way, the indicator bulb is also LED.
Thanks for all the help guys!
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
Jake Correct generator pulley and fan? Pics needed Austin Healey 5
