Correct orientation of the fan blades.
Ian R
Member
Hi all, I'm confused over the orientation or the fan blades on my BN4.
As I received the car the fan had two blades facing one way and two facing the other ?
Is this correct ? It had a water pump change at some time so could have been put back wrong...
Photo would be helpful...Thanks...Ian.
British_Recovery
Bronze
I
Ian R
Member
Thanks for the info. They were on wrong then..!
So when fitted correctly the 4 blades are not at 90 degrees to each other..seems odd !
Is this to gain access to something.?
I can see why they were put on wrongly.
The non-90 degree disposition makes them quieter.
I concur. You'll notice too that most well thought out fans, OE or aftermarket use an odd number of blades, sometimes staggered (not equidistant from each other).
As Steve states, all in the effort to reduce noise.
I can only imagine the efficiency of running a pair of blades facing opposite each other__was it moving much air at all, or canceling each pair out?
I
Ian R
Member
I wouldn't know about the fan effectiveness , I've never heard the car run..!
I bought it from Arizona nearly 2 years ago as a non runner. In fact I dont think it it has run for about 30 years.
I'm trying to do a full resto on it....I keep telling myself "it's a marathon not a sprint...!
Some photos, if they upload..!
British_Recovery
Bronze
It looks like you went to 60 spoke wheels. Make sure the spokes don't come in contact with the drums in the front. Rears clear, but some 60 spoke wheels will rub.
Keoke
Yeah nice, But when he got it -it don't look like no AZ car probably came from Florida N got stuck in AZ??--LOL
I
Ian R
Member
Was imported to dealership in Seattle, Washington December 1958....where it went from there is anyone's guess.....
G Shift Boot Install - Correct Orientation Austin Healey 7
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
