MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset?
Vardaman
Member
I've been poking around trying to find a car make that has relatively attractive alloy wheels that would fit my '66, since the existing steel wheels are tragically bent and having them straightened would be cost-prohibitive. I figure it would be easier to just ask if anyone has found a set that works--either by trial and error, or by better research than I'm able to do. Can anyone recommend a set of used alloys in the proper size?
P.S. Not to offend anyone, but I don't care to be lectured on why only the originals are appropriate, or why Rostyles are what I'm really after. I hope that's OK.
Platinum
Saab had a Minilite alloy on some of their production cars years ago. One of our apparently M.I.A. forum members had a set fitted to his MGB. Nunyas by forum name. Might try a search.
AngliaGT
SAABs are front wheel drive - wouldn't the offset be wrong?
V
Vardaman
Member
They look good, but they're 15s. Mine has 14s, and I have already bought tires so I'm looking for 14s.
JPSmit
here are the cars with the same bolt pattern
most makers offer a variety of sizes
more options here:
some very tasty ebay options also
Joe Reed
Be sure to watch the size of the center hole. If the Supra wheel has a 60.1 mm center hole, it may be a problem. I don't recall the size required for the MGB but I believe it's larger than that....
billspohn
Datsun 240Z work although they are wider.
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
D Stock Camshaft TVR 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
nichola TR6 Stock exhaust sound... short video Triumph 4
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
S TR2/3/3A stock fog light Triumph 2
PC Actually in stock? Spotted 0
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
R Upgraded rod bolts for stock rods Austin Healey 1
S New Build Stock Wheels? Spridgets 38
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
B Wanted stock Bj8 distributor Austin Healey Classifieds 1
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
simon1966 Rarity of Stock 100! :-] Austin Healey 13
T Front Tilt or Stock Fit Bonnet Spridgets 18
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
T Tilting the stock seat for comfort Spridgets 6
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T WW Axles in stock Bugeye housing? Spridgets 7
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
G TR6 TR6 air filter element replacements for stock housing Triumph 3
CJD TR2/3/3A Stock Valve Lift Triumph 3
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
CJD General TR BSW thread stock Triumph 2
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
B Found more unopened stock to ofer/trade/giveaway to a good home Spridgets 0
C Stock seat belt color? Austin Healey 11
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
Ed_K Modifing the stock BJ8 air cleaners Austin Healey 0
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
D Stock oil filter vs spin on filter Austin Healey 17
R Planing my built. Stock vs transplant Spridgets 58
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T stock bugeye front springs Spridgets 4
T Milling a head on a Stock 1275 for compression? Spridgets 13
T TR2/3/3A Is stock TR3A windshield tinted or clear? Triumph 9
CraigCootsona MGA 6x15" wheels on a stock MGA? MG 18
