Converting a MkII with a V8 back to stock Jag 6?
karls59tr
Bronze
I've seen some pretty decent looking MkII's that have had there drivetrains converted to GM V8's or straight Six's. Has anyone attempted to return one of these altered Jags back to stock and what kind of issues did they run into when doing this?
Deleted member 8987
The issue I have seen, going way back, is firewall and tunnel.
I recall a 283 and powerglide in a MK1 in....1966 that had patched "hump: to clear the trans, and I think the firewall notched back to clear the distributor.
But, since the mounts are to the subframe, and not the body, I would think most of the damage can be repaired by obtaining a new (used) front subframe.
If they whacked out for a bigger radiator, you'd have to fix the mounts.
Might take a rusty "donor" car, but should be reversible.
Tach is maybe another issue....and "donor: may fix that, too.
K
karls59tr
Bronze
Thanks for the info. Do you ever come across donor cars in the Washington area or are they mostly found in the California/Arizona area?
Deleted member 8987
You can find donor cars about anyplace. Less rust in dry areas, hopeless in places where they salt the road. But, those inner pieces should be fairly well protected.
nevets interesting article about converting classic cars to electric power Austin Healey 7
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
K TR2/3/3A Converting to Negative Ground....... Triumph 12
K TR2/3/3A Converting to Positive Ground....... Triumph 1
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
drooartz MGB-GT Decided - converting to bolt-on wheels MG 3
T Converting a BJ8 into a racer Austin Healey 8
drambuie Converting a smiths clock to positive ground Austin Healey 12
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Mark_Barton TR4/4A Converting to ballasted ignition? '62 TR4 Triumph 8
T converting disc wheel BN4 to disc brakes Austin Healey 12
T Stag Converting a Stag from auto to a 5 speed Triumph 3
B Converting to Neg ground Spridgets 5
AH67 Converting wheels on a 62 BT7 Austin Healey 3
C Converting to DOT 5 Triumph 6
T TR2/3/3A Converting TR3A to Wire Wheels - Torque Specs? Triumph 3
middie Converting from US to UK radiator in a late 1500 Spridgets 10
L Converting a Midget MG 8
MadRiver Converting to a Surrey Top Triumph 5
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
Z Converting Power/Torque to Metric Units Austin Healey 1
Newkie Converting Positive ground to Negative ground MG 4
QuickSilver Converting Rubber To Chrome MG 1
M Converting to RHD Austin Healey 8
amcboy Post-War Other Difficulty in converting Volvo 1800 J-type O/D? Triumph 6
T converting rear reflector to brake light Austin Healey 16
spit71 Spitfire Converting track width on MKIV Spit? Triumph 5
S Converting to Negative Earth Spridgets 15
Camshaft Converting BACK to lever shocks MG 5
pan Rear axle- Converting to wire wheels Austin Healey 6
drooartz Feeling stupid -- converting tachs Spridgets 11
drooartz Converting to RHD Spridgets 10
soren_ak converting a BN 1 100-4 ´55 from LHD to RHD Austin Healey 1
kyreb1862 Converting to SU's MG 9
T Converting a 3000 back from a V8 conversion Austin Healey 7
R Converting Rear Reflector to working lamp Austin Healey 77
S converting from wire wheels to studs Spridgets 4
A TR4/4A Converting TR4 gear box to O/D Triumph 4
N MGB-GT Converting A 77 B GT from RHD to LHD MG 7
A Converting a non-o.d. tranny to a J-type Triumph 12
TR4 Converting from Stromberg to Weber Carbs? Triumph 23
W Converting to wire wheels MG 1
L Rust Inhibiting or Converting Paints Austin Healey 1
W Converting from American to British Bumpers? Jaguar 1
S Converting from a knock-off to a 5-bolt hub. Jaguar 1
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
L For Sale 1952 MG TD MkII MG Classifieds 2
Alfred E. Neuman Red MGA MkII Spotted 1
