TR4/4A Converting TR4a from wire to TR6 steel wheels
tdskip
Hi guys - my wire wheels have had it and am looking to (on a budget) get slightly wider profile tires on the car. I have a spare set of TR6 rims that I'd like to us, but a fuzzy part of my brain (insert joke there, keep it clean) is saying the lug nut studs need to be longer than the ones the wire wheel spine extensions use. If so I am assuming Moss etc caries the correct studs to use? Will the existing studs just knock out readily or do they need to be pressed out at a machine shop? New ones pressed in if so?
So many questions...
Thanks!
TR4nut
Tom -
is is your car IRS or solid axle? IRS is easy and yes just buy TR6 lugs. The solid axle is like the TR3 and TR4 though, the rear lugs are threaded in and a little more challenging to change out.
trrdster2000
Skip, They will come out with one good whack, but do yourself a favor, or someone in the future. Run a lug on the threads before hitting them. You may want to go back or someone may do a wire wheel conversion and need a couple. The new ones will pull in with a lug nut on a 1/2 inch spacer, washers, if that's all you have. Give them a spray with WD40 or a drop of grease before hand.
Wayne
M_Pied_Lourd
Thanks Wayne, and good tip about maki sure to not damage the threads.
Someone will correct me if I'm wrong, but I believe to put longer studs in the front, you will need to split the hub from the rotor to be able to get them in...
Cheers
Tush
nevets interesting article about converting classic cars to electric power Austin Healey 7
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
K TR2/3/3A Converting to Negative Ground....... Triumph 12
K TR2/3/3A Converting to Positive Ground....... Triumph 1
drooartz MGB-GT Decided - converting to bolt-on wheels MG 3
T Converting a BJ8 into a racer Austin Healey 8
drambuie Converting a smiths clock to positive ground Austin Healey 12
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Mark_Barton TR4/4A Converting to ballasted ignition? '62 TR4 Triumph 8
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
T converting disc wheel BN4 to disc brakes Austin Healey 12
T Stag Converting a Stag from auto to a 5 speed Triumph 3
B Converting to Neg ground Spridgets 5
AH67 Converting wheels on a 62 BT7 Austin Healey 3
C Converting to DOT 5 Triumph 6
T TR2/3/3A Converting TR3A to Wire Wheels - Torque Specs? Triumph 3
middie Converting from US to UK radiator in a late 1500 Spridgets 10
L Converting a Midget MG 8
MadRiver Converting to a Surrey Top Triumph 5
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
Z Converting Power/Torque to Metric Units Austin Healey 1
Newkie Converting Positive ground to Negative ground MG 4
QuickSilver Converting Rubber To Chrome MG 1
M Converting to RHD Austin Healey 8
amcboy Post-War Other Difficulty in converting Volvo 1800 J-type O/D? Triumph 6
T converting rear reflector to brake light Austin Healey 16
spit71 Spitfire Converting track width on MKIV Spit? Triumph 5
S Converting to Negative Earth Spridgets 15
Camshaft Converting BACK to lever shocks MG 5
pan Rear axle- Converting to wire wheels Austin Healey 6
drooartz Feeling stupid -- converting tachs Spridgets 11
drooartz Converting to RHD Spridgets 10
soren_ak converting a BN 1 100-4 ´55 from LHD to RHD Austin Healey 1
kyreb1862 Converting to SU's MG 9
T Converting a 3000 back from a V8 conversion Austin Healey 7
R Converting Rear Reflector to working lamp Austin Healey 77
S converting from wire wheels to studs Spridgets 4
A TR4/4A Converting TR4 gear box to O/D Triumph 4
N MGB-GT Converting A 77 B GT from RHD to LHD MG 7
A Converting a non-o.d. tranny to a J-type Triumph 12
TR4 Converting from Stromberg to Weber Carbs? Triumph 23
W Converting to wire wheels MG 1
L Rust Inhibiting or Converting Paints Austin Healey 1
W Converting from American to British Bumpers? Jaguar 1
S Converting from a knock-off to a 5-bolt hub. Jaguar 1
T TR4/4A Triumph TR4A 1965 price Triumph 8
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
