General TR BSW thread stock
CJD
I am working on the NLA wiper motor. In addition to needing a new commutator (which I actually did find)...the mounting system uses 1-1/2" lengths of Whitworth threaded posts. Does anyone know of a supplier for whitworth threaded stock...or long bolts in the 10-33 size range?
Thanks
T BSW Filler Plug Armstrong Rear Shocks? Spridgets 2
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
timbn2 Whitworth / BSW tap and die question??? Austin Healey 25
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
J Next Thread? FORUM Navigation Questions 1
L Little1's 75 Midget 1500 Thread Spridgets 14
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
C My 2500M progress/questions thread TVR 5
JFS Wedge Stripped gearbox filler hole thread Triumph 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
charlie74 Wanted Thread restorer kit Triumph Classifieds 0
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
J TR2/3/3A such strange thread on gear shift knob Triumph 12
J Thread Locker on Shock Bolts? Austin Healey 19
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
JPSmit Spridget thread question FORUM Navigation Questions 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
B TR6 Boot lid thread plates loose in stiffener Triumph 1
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
Editor_Reid Parts List Thread Now "Sticky" - parked at the top of this list of subjects Austin Healey 0
Boink Rolls-Royce head replacement thread... Other British Cars 0
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
rvm Annulus shaft thread measurements? Austin Healey 12
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
nevets How do I unsubscribe to a forum thread??? FORUM Navigation Questions 2
B General Tech Waking up a sleeping car thread MG 1
JimLaney Anti-seize or Thread locker ? Spridgets 2
W TR2/3/3A Glaciers move faster - my build thread Triumph 0
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
B Stripped Thread in Gas Tank Austin Healey 26
J anybody tell me why this thread closed? Austin Healey 4
T TR2/3/3A Another wheel bearing thread Triumph 5
Boink Waterless Coolant - thread from the AH forum Spridgets 18
Rut TR4/4A steering shaft/nut thread size Triumph 5
Editor_Reid New "Parked" thread at the top Austin Healey 0
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
B TR2/3/3A end of me water pump thread Triumph 2
