MGA 6x15" wheels on a stock MGA?
CraigCootsona
Member
Hello all,
I'm considering purchasing the 6"x15" "M" type aluminum wheels listed at the following site: https://www.racemettleltd.co.uk/wheel.html for my MGA. The car has stock wheel wells without flairs or widening. I'm wondering if anyone knows if this width of wheel will interfere? Also, I believe most MGA's used the 42mm size splined hubs rather than the 52mm? Can anyone confirm?
Thanks,
Craig
Re: 6x15" wheels on a stock MGA?
We've used 15x6 +24mm offset bolt on wheels on MGAs with no issues
CraigCootsona
CraigCootsona
Member
Thanks for the quick response Hap! The easy part is done. . . Now I just have to convince the wife that the price is worth it!
billspohn
Craig, IIRC, those wheels are hugely expensive. Are you sure you wouldn't be as happy with a premium quality wire wheel like Dayton (assuming you have wire wheel hubs - and yes, all MGs use 42 mm splines)? They would probably be cheaper and would (IMHO) look better.
BTW, it isn't the 6" rim width that causes problems on the MGA, it is the tire you put on them. Be very careful and see if you can mount an old tire in the exact size you want to buy and try it out on the car, preferably driving a bit and doing some cornering before committing to a purchase.
Unfortunately the dimensions of two identical size tires from two different makers can vary, so unless you are able to find a core take-off of the same exact tire there would still be some uncertainty....
billspohn
PS - 185 x 65 - 15 work well.
CraigCootsona
CraigCootsona
Member
Thanks for the warning on tire size. . . I hadn't thought about that aspect yet. If anyone on this thread has recommendations of brand and dimensions that are known to work with 6" wheels, that would be a start.
Yes, the racemettle products are quite spendy about $440 USD each, but I notice that victoria british sells their chrome 72-spoke for about the same. I do admit that I like the solid feel of the center lock alloy wheels on my MGB over wires, but the wires were quite old when I had them. I might consider a painted wire wheel if I can think of a nice complementary color to contrast the blue body. I've always enjoyed the look of the old Jag XK's with colored wheels. I have some time to think this over because the wheels are the last thing I'll do.
I would really prefer to find some original twin cam/MkII deluxe wheels with the peg drive and the corresponding peg drive hubs because I like the concept of peg drive, but they are rare as hen's teeth. If anyone has some collecting dust of knows of a source, please contact me and we can talk.
Craig
billspohn
You can get tubeless 72 spoke Daytons for far less than the Racemettle wheels.
Or I can maybe put you onto a conversion set with Dunlop peg drive and suspension in the $5K range, if you really want to spend money.
My coupe has the 185x65 tires on widened 5.5" rims.
CraigCootsona
CraigCootsona
Member
Beautiful car and great wheels! How much would just the peg drive suspension run without the wheels?
billspohn
Seller won't separate them.
billspohn
The knock off wheels are not spline drive, they have 4 pegs that fit into holes in the hubs.
BRM and D type Jaguars also used this special Dunlop wheel type.
billspohn
PS - another widened set in action on another of my cars, and a pic of the engine bay. Not your normal MGAs.
Sandman_Slim
Aw man,what is that?! That engine is something! It really started life as an MGA twin cam? You got some cars dude... Some guys know how to live.
billspohn
Yeah, just a regular old MGA engine..... :devilgrin:
CraigCootsona
CraigCootsona
Member
5K is a little more that I was hoping to spend. In light of billspohn's comments I'm considering wires! Can you tell me who sells the tubeless Daytons?
Great pics! It's interesting to see that the carbs and distributor are on the "other" sides of the twin cam engine. I've never really looked that closely at them.
Is it correct to say that pegs would be less prone to wear than the splines? I always wondered why all cars didn't run with pegs because it seems to be less machining to make 4 holes.
billspohn
The pegs were intended for quick changes in competition, although I expect they would also result in reduced wear.
The guy that sells Daytons (a lot on ebay) is:
Classic Car Performance, Inc.
142 Wagmans Ridge Rd
Saratoga Springs, NY 12866
518-290-0390 Cell (call anytime)
516-417-8391 Fax
dave@classiccarperformance.com
CraigCootsona
CraigCootsona
Member
Well, I finally decided to order the Racemettle wheels with splined hubs. They weren't too bad, pricewise compared to a set of 72-spoke wires. They take some time to manufacture and ship, probably because the shop they use to make them takes larger orders with higher priority. I'll send pics when they arrive.
Craig
billspohn
The problem with the alloy wheels is that the splined portion, almost universally done in steel, make the nice alloy wheel weigh more than the equivalent wire wheel.
Aside from looks, there is really no reason to stick with knock off wheels from the performance point of view.
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M For Sale Vintage Modular HTN 3 Piece Racing Wheels 13" Triumph Classifieds 0
B Wheels and Tires Selection Austin Healey 10
F MGB-GT what do these wheels go to MG 1
CARSINC My Spyder-Mite Gets Wheels Spridgets 9
K TR2/3/3A American Racing Slot Wheels Triumph 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
T "Flashpower" Steering Wheels Austin Healey 3
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W For Sale Wheels for sale Austin Healey Classifieds 1
glemon Wanted TR250 Wheels Triumph Classifieds 1
D MGB BWA Alloy Wheels MG 9
T TR2/3/3A minilite wheels Triumph 5
R Bugeye splined wheels Spridgets 0
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
P TR5/TR250 Wire wheels width Triumph 8
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Wire Wheels and Air Leak Austin Healey 16
algot1901 Wheels or Rims Lug Pattern Other British Cars 12
drooartz New wheels and tires for Penny Spridgets 16
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
Y MGB Aftermarket wheels MG 5
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
R MGA wheels MG 10
F For Sale: Minilite Style Knockoff Wheels, 15" x 5.5" Austin Healey Classifieds 2
F TR6 Wheels and tires Triumph 10
T Wanted. 14"-16" Vintage wood steering wheels Other British Classifieds 3
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
M TR6 Center cap for wheels Triumph 2
C Replacement wheels Rover / Land Rover 1
B Refinishing Minilite Magnesium wheels Restoration & Tools 0
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Recommendation on wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
DerekJ Original steering wheels Austin Healey 1
B TR2/3/3A Tubes in steel wheels? Triumph 18
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
