TR2/3/3A Lightening a stock TR3A flywheel.....
karls59tr
Bronze
I have to pull the gearbox to change out the clutch and get the flywheel resurfaced. I was wondering about lightening the stock flywheel.I don't want to go to the expense of installing an aluminum flywheel and I do know a machinist that would do it for a reasonable price. I was wondering if anyone had any information as to where to drill the flywheel and how much to take off etc. How would a lightened flywheel affect performance and what would I have to adjust in terms of retuning the engine?My 3 has a rebuilt motor, Petronix,a header,mild street cam,stock SU's,4A intake. Is doing this worth the effort or am I wasting my time for a small gain in performance?
tinman58
Karl
I just had my flywheel lightened by 7 lbs. That was the most the machinist thought was safe. My engine sounds similar to yours except I have the Moss Supercharger. The extra zip is worth the expense. The machinist had to enlarge the hole at the center of the flywheel to mount the flywheel on the lathe. I gave him the pressure plate and let him do the layout. For the amount of cost ($250) I think it is a lot of fun for the buck.
TR3driver
Great Pumpkin - R.I.P
Here's a photo that might help
That's a billet steel flywheel (from ARE), rather than a cut-down original, but it shows the areas that need to be left and the ones that can be removed.
I have a Fidanza aluminum flywheel on my TR3, which at 10 pounds is much lighter than you can take the stock cast iron wheel (without risk of having your feet amputated anyway). I didn't make any special changes to the motor, but note that you want good low end torque or the car will be harder to launch. The engine in my TR3A didn't pull so well at low rpm, and it was a bit of a learning experience not to kill the engine when driving casually. The motor in my current TR3 pulls better below 1500 rpm, and I've still killed it once or twice.
I see the Fidanzas have gone up since I bought mine some 20 years ago, but still only $310 at Amazon. For $60 more, I'd still go that way. But note that the Fidanza comes drilled only for the TR4A clutch. You'll need to either use a TR4A pressure plate, TOB & carrier to match it, or have it redrilled for the earlier clutch. I went the TR4A route, as it is also lighter than the stock TR3-4 clutch.
TR3driver
I believe there are instructions as well as a drawing in one of Kas Kastners Competition books.
I was just looking for that, with no luck. If you happen to remember which one, please let us/me know.
TR3driver
Ah, OK, I found that passage in the 2003 version "Triumph Preparation Handbook", page 121. No diagram though, and the photo shows a lot of work that wasn't done on a lathe. The original factory TR3 & TR4 "Competition Preparation" manuals (which were also written by Kas Kastner) just say to use aluminum.
K
karls59tr
Bronze
Karl
Where did your machinist remove the material from the flywheel? One of the replies to my question led to what Kastner said on the topic..."most weight is taken from the outside and on the cylinder block side"....not sure what is meant by the outside?
Bremer
I interpret this to mean that most of the material was removed close to the outer diameter of the part as opposed to close to the center.
tomshobby
I have had a Fidanza on my TR6 for several years. I thought it was closer to 9 lbs but may be wrong. It is great at low end and acceleration and impressive in the mountains (in the East or West) on up hill grades even pulling a trailer. I agree with Randall's comments. Although I haven't had problems stalling my 6.
TR3driver
MDCanaday
The original tr2 flywheel tipped in at 23 lbs, the tr3 at 32 lbs .If you can lose
9 or 10 lbs it is nice.The tr2 unit had a lot of metal off the engine side and was a little
weaker.I like the off the perimeter approach as in the picture. It saves rotational inertia
which is the real issue.When you do this , it should be balanced to the crankshaft it will
be married to.....
MD(mad dog)
bertl
Member
Here is a drawing I made from a sketch that I got from Herman van den Akker. I plan to install his HDVA conversion in my restore project. His kit requires the TR6 pressure plate so the stock flywheel has to be re-drilled to fit it.
A Lightening the Sprite Spridgets 14
T Lightening BN1 Flywheel Austin Healey 5
vping MGB MGB Flywheel lightening MG 6
T TR4/4A Lightening a TR4a flywheel - a couple of questions Triumph 7
T TR4/4A tr4 engine block lightening-how much? where? Triumph 5
T block lightening-tr2,3,4- how much-where Racing 22
D Stock Camshaft TVR 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
nichola TR6 Stock exhaust sound... short video Triumph 4
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
S TR2/3/3A stock fog light Triumph 2
PC Actually in stock? Spotted 0
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
R Upgraded rod bolts for stock rods Austin Healey 1
S New Build Stock Wheels? Spridgets 38
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
B Wanted stock Bj8 distributor Austin Healey Classifieds 1
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
simon1966 Rarity of Stock 100! :-] Austin Healey 13
T Front Tilt or Stock Fit Bonnet Spridgets 18
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
T Tilting the stock seat for comfort Spridgets 6
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T WW Axles in stock Bugeye housing? Spridgets 7
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
G TR6 TR6 air filter element replacements for stock housing Triumph 3
CJD TR2/3/3A Stock Valve Lift Triumph 3
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
CJD General TR BSW thread stock Triumph 2
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
B Found more unopened stock to ofer/trade/giveaway to a good home Spridgets 0
C Stock seat belt color? Austin Healey 11
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
Ed_K Modifing the stock BJ8 air cleaners Austin Healey 0
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
D Stock oil filter vs spin on filter Austin Healey 17
