Ground clearance is measured from the ground to the lowest part of the vehicle, which is the bottom of the frame for a TR4A. As the gentlemen above mentioned, this will be affected by the static loaded radius of the tires, any wear or compression in the suspension bushings, the rubber spring packing, and the amount of load, including the amount of fuel in the tank, etc.
If the ground clearance measured at the front is close to that measured at the rear (before the frame starts to angle up) I'd venture the springs are probably OK. Theoretically at least, springs shouldn't sag if properly designed until they start cracking due to fatigue. Up until then they should be operating safely in the elastic region of the material, and not in the plastic region that would be necessary for the spring to sag under normal operating conditions.
Hope this helps,
Jim
