General TR TR4A Seat Rebuild
RJS
Hi Everyone,
Mine is a 66 TR4A which I've owned 20 years. The PO installed new vinyl upholstery and my seats look good. But, he re-used the original internals and now the foam innards are really starting to disintegrate and fall apart.
My question: how likely is it that I can remove the upholstery safely, rebuild my seats and re-install the current upholstery without damaging it? I am probably most concerned if the upholstery is glued on in any fashion (which may make removal dicey).
Thanks
Bob
Sarastro
If it's done properly, you should be able to do this. The covers are held on by clips, which are easy to remove.
See > TR4A Seat Rebuild Instructions - Attached : TR4 & TR4A Forum : Triumph Experience Car Forums : The Triumph Experience < for good seat-rebuilding instructions; this is the best I've found. Also > Interior Restoration < gives my experience.
When you get them apart, you may find some surprises. The frames often have a lot of rust and may need repair. Seat covers are often installed over old covers, and auto upholsterers often do things their own way. Seats, also, are beloved nesting places for mice. It might be a bigger job than you expect.
RJS
RJS
Steve
Thanks so much for the resources. These are truly amazing in their detail. Glad to hear the upholstery should come off intact. But, I'll take a close read to determine if this is something I can take-on myself - or if best left to a professional. Most mechanical things I am game to tackle. But upholstery is a bit of an art.
Bob
PS: I'll be exploring the rest of your website this afternoon. Extremely well done - thanks!
Geo Hahn
I have fearlessly upholstered 4 British cars without really knowing what I was doing. Not all that difficult and many of the steps allow re-do if the first attempt doesn't meet your standards.
If the PO used glue it was likely contact cement which a modest application of heat can often permit disassembly.
The first time I did my TR3 I removed the old vinyl covers to find under them.... a set of older vinyl covers. Pulled those off too and found... a set of old leather covers (probably the originals).
glemon
When I redid my TR250 seats I didn't replace the foams, 6-7 years later as the seats continued to rapidly disintigrate I decided that was a mistake, and took them apart again and added foam. Like brakes and carburators they come in pairs on our cars, do one at a time and you will have the other for reference. No special tools needed, strong hands for stretching and clamping stuff helps.
DavidApp
I found the seat padding that The Roadster factory sells is very good. I had bought a complete upholstery kit from the UK but it came with foam rubber seat padding that I could not get to work well.
Got some more padding from TRF to use in place of the foam rubber padding and am very pleased with the results.
David
Rut
I can attest to the instructions Steve posted the link to as I’m now the caretaker of Jim’s Desert TR. Jim did a beautiful job on the seats and everything else.
Rut
Popeye
Bronze
I am pretty sure there was an article on BCF on seat rebuilding? It was a few years ago, but I found it really helpful.
What happened to the articles section? I'm still navigating my way around the new forum (I really like it - but need to learn a few new "tricks").
RJS
RJS
This is really encouraging info. I will pull the seats (one at a time) once we get some warmer Spring weather and seriously consider rebuilding myself. If only the foam cushions were available - they appear to be BO'd everywhere.
Bob
RJS
RJS
OK, I take that back. I just looked and Rimmer Bros in the UK has the cushions in stock
Madflyer
All the above is spot on, would add the rubber bladder can be a pain they may want it to tight I think it should fit with out to much pull your tail will do the rest. If all new foam slip a plastics bag over the back to slide cover back on just leave it there. Not only will you find rust but enough change for a cup of coffee. Madflyer
Popeye
Bronze
Yes - that was the write up, Alan Turner! Great document... anyone know where it went to?
Popeye Contact adhesive for open cell foam - seat rebuild [TR4A] Restoration & Tools 8
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
J TR4/4A TR4A seat retaining clip Triumph 5
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
R TR4/4A Best seat foam kits for TR4a? Triumph 3
alanjohnturner TR4/4A TR4A seat restoration Triumph 13
Stinger TR4/4A TR4A Seat Belt Badge and Side Lamp Lens Triumph 8
T TR4/4A Retractible 3-point seat belts for TR4a Triumph 6
rlich8 TR4/4A TR4A Seat and Carpet Questions Triumph 5
R TR4/4A tr4 / tr4a seat frames Triumph 9
R TR4/4A Seat foam tr4a Triumph 4
T Wedge TR4a, TR6 and TR8 seat webbing's interchangeable? Triumph 2
S TR4/4A TR4A Seat Belts Triumph 7
R TR4/4A Moss tr4a Seat and panel kits anyone use them? Triumph 0
C TR4/4A TR4A seat replacement? Triumph 5
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
