TR4/4A Recommendation on top for a late TR4A
tdskip
Hello gentlemen, belated best wishes for 2021.
I'm back to picking at the '66 TR4a and it is time for a new top, any suggestions on sourcing that? More concerned with functional and long lasting than absolutely period correct.
Thanks!
bammons
I will be in the market soon and will be watching to see what people say. As far as I can tell only Robbins and Prestige are the main sources. I don't know anything about Prestige. The color choices once you get away from black are limited. Bruce
sail
I think mine is an Everflex from TRF. It's black rubber outside with a gray cloth liner. I tried to find one with tan inside as original but couldn't. I do like the lighter interior when the top is up. I think for longevity the most important thing is care of the window when folding. I'll see if I can find a receipt in a very large pile that I normally choose to ignore.
Geo Hahn
Mine's a TR4 but I'll mention it anyway -- can't imagine being in the Southwest w/o a zip down rear window. Okay, pretty useful anywhere I suppose:
I think it is Everflex - a somewhat stretchy material.
Madflyer
Sorry it has been to long since I did my TR 6 but I got the light tan inter door panels and extra vinyl for my seats from V B I then took a sample of same and sent to the UK for a matching top I could get any color at that time I did get the zipper window but did not think I ever unzipped it as I run top down most year round. UK is having a hard time right now but not imposable revingtonTR in the UK may be able to help
Madflyer
T
tdskip
So top up for sun protections but windows down and rear window unzipped for air flow?
Geo Hahn
Yes, that's the formula. Out-of-state trips seem to begin and end with a couple of long days in the sunshine. I also have a zip-out on the E-Type for the same reason.
Sarastro
I just installed a Robbins vinyl top on my TR4A, and I find it completely adequate. It seems to be of good quality, and I suspect it will last longer than I keep the car.
Back in the 1960s, the rear window of my TR4A top turned yellow in a couple years, and I replaced it soon after. If the window material is still that bad, I see no point in spending more for the top. However, I think it's likely that the quality of the material has improved in the last half century or so.
Marvin Gruber BJ8 convertible top recommendation? Austin Healey 0
L TR4/4A Surrey Top repair recommendation Triumph 2
T Recommendation for a new top Spridgets 8
G TR5/TR250 TR 250 top recommendation Triumph 0
L Gas Cap Recommendation Austin Healey 1
J T-Series Mechanic recommendation MG 0
J Request for soldering iron recommendation Restoration & Tools 6
B TR6 Help with color and color code / paint recommendation Triumph 4
B Recommendation on wheels Austin Healey 19
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
S TR2/3/3A Front coil spring recommendation? Triumph 7
JimTR4 TR4/4A Battery recommendation Triumph 11
S Grease Gun Recommendation? Spridgets 7
M General MG Shop recommendation....Baltimore - Washington corridor MG 9
M TR2/3/3A Shop recommendation---Baltimore-Washington corridor??? Triumph 4
maxwedge5281 auto transport recommendation Austin Healey 10
G General TR Machine shop recommendation around Green Bay, WI Triumph 1
R Seeking Upholster Recommendation Austin Healey 4
D Recommendation for new core in original 1967 Austin Healey radiator Austin Healey 5
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C Recommendation for Healey mechanic in Naples/Ft. Myers Florida area? Austin Healey 11
S Rust treatment recommendation? Austin Healey 5
P Good fitting car cover recommendation? Austin Healey 9
DornTRoriginal TR2/3/3A TR3 Battery Recommendation Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
I Bigeye fuel filter and placement recommendation? Spridgets 8
T TR2/3/3A Camshaft Recommendation Triumph 13
tmcarthur Tool Recommendation Spridgets 7
PAUL161 T-Series New Firestone Tires Recommendation MG 2
B Recommendation for Healey Blue and Old English White Paint Austin Healey 15
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
B Replacement Interior Recommendation Austin Healey 11
J Lotus europa 5 speed need recommendation for transmition work [Flordia] Lotus 3
J Restorer recommendation Austin Healey 33
P Overheating after shut down & recommendation on thermostat Austin Healey 3
M Pebble Beach/ Monterey Good Accommodations Recommendation Austin Healey 13
S Texas restoration recommendation? Austin Healey 2
B Interior Recommendation Austin Healey 8
H Carb rebuilder recommendation? Triumph 5
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
L PPI recommendation, Jacksonville? Austin Healey 2
B Battery recommendation besides Optima Austin Healey 17
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
boeingpilot Shop recommendation Ft. Worth, TX Triumph 11
E TR6 TR-6 Tune Up Shop Recommendation Triumph 7
D Steering Wheel Recommendation MG 4
G SU book recommendation needed Spridgets 7
Michael Oritt Need muffler recommendation Austin Healey 16
