Request for soldering iron recommendation
TPStricklin
I would recommend crimping the wires with a high quality tool. If you are looking for a soldering iron, I would recommend a suitable Weller.
equiprx
Hi,
What soldering iron do you recommend for soldering car wires?
Get one with adjustable heat/wattage.
Most of the time too much heat will kill the insulation.
Another feature would be easily changed variety of tips.
I have about five different irons but would love to get one that does everything.
Popeye
Bronze
Having used a $5 radio shack iron for 20+ years, last Christmas I bought myself a Hakko FX-888D.
It’s a purchase I wish I made 20 years ago - it is that much better. Heats quickly, I can adjust the temperature and the tip depending on what I’m doing, and it has a stand to hold the (hot) iron instead of it precariously balanced off the edge of the workbench.
As TPS said above, Weller also makes a great soldering iron. I must have picked the Hakko for a reason, but can’t seem to remember it. Both will be miles better than a $5 tool.
A good soldering iron and a Fluke multimeter, both expensive investments, were two of the best tool purchases I’ve made. They simplify and improve the quality of my work immensely!
Gliderman8
My Weller has three LED lights around the base. It really helps when working in tight places to shine some light on where you're soldering.
mezy
I have dremmel gas iron, Heats up real quick, dont need wires trailing about the place, hand if you have a quick little soldering job to do.
Also great for welding plastic bumpers too.
donbmw
After going through many different brands of iron’s doing stained glass. I broke down and bought a Hakko 601 for my stained glass work and a 600 to use at work. I have found that the temperature control of them lets solder longer before I need to let it heat up.
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
Y MGB An odd (and probable long-shot) request... MG 5
A Hello from new member, and car identification help request Other British Cars 9
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
bfitz Vendor info request Restoration & Tools 10
Elva164 A New Race Video and a Request! Racing 3
SASSAMON TR2/3/3A Intro and Request For Help Triumph 5
L Request help with identifying this AH 1960 3000 part. Austin Healey 1
T Question on request for parts FORUM Navigation Questions 3
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
dklawson Sorry... Urgent Request for Friend - Marina Front Engine Plate Other British Cars 2
dklawson MGB Sorry... Urgent Request for Friend - Marina Front Engine Plate MG 3
D Spitfire Spitfire track width measurement request. Triumph 3
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
RAC68 Request Battery Cable Length Austin Healey 3
PHerder Request for a part... Spridgets 7
A TR7 SU Conversion- Request to the MG Guys MG 4
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
T photo - odd request Triumph 5
T TR2/3/3A TR2 Sway bar questions/info request Triumph 5
Mowgli81 Back Seat Hinge Request Austin Healey 2
RickB My request to my family for Christmas Spridgets 7
B Midget 50th - The BIG Party Caravan request! Spridgets 0
T NLA SU HS6 part request Triumph 10
P GT6 Michigan request for help evaluating GT6 Triumph 6
P GT6 GT6 evaluation request Triumph 18
H Air Deflector Assembly Hardware Help Request Austin Healey 2
W TR2/3/3A TR3 Door Seal Rubber Question photo request Triumph 4
TR3driver TR2/3/3A TR2 history request Triumph 4
dklawson Spitfire Picture Request - Late Spitfire Hardtop Seals Triumph 3
theleisure Pix Request, "Oil Filter Switch" Spridgets 9
theleisure Tonneau Cover Photo Request Spridgets 1
J Clutch Fork Clearance Info Request Spridgets 2
Tim Tucker Vote Request Triumph 1
dklawson Dimension/Picture Request - RotoFlex Triumph 4
dklawson Spitfire Spitfire Steering Column - Picture Request Triumph 6
pan Request for help for Aussies in trouble in Italy Austin Healey 7
healeyboz another weird request Spridgets 1
healeyboz strange measurement request Spridgets 29
amcboy Mmmmm Carb Floats... And a request for opinions.. Triumph 10
M Part request Can anyone help? Spridgets 3
tosoutherncars Picture request - RB car, chrome rear bumper Spridgets 8
Shealey New parts hunting request. Spridgets 4
B Request help with a [BJ7] interior measurement Austin Healey 9
Brooklands TR2/3/3A TR3 Engine Suggestion Request Triumph 16
jlaird I have a request Spridgets 7
T A photo request Triumph 36
T E-mail request Triumph 2
T Reference check request Austin Healey 4
JPSmit Sheet Metal request Spridgets 5
