Spitfire Spitfire Steering Column - Picture Request
dklawson
Our project Spitfire came to us as the previous owner's unfinished project.
The owner before them had lost the ignition keys so the last owner bought a new lock assembly and "cut" the old lock off. To do this they removed all the under-dash support brackets. What's there now is an ignition switch lying on what's left of the driver's footwell, and a pile of parts sitting below a steering wheel hovering in space.
I've looked in the VB catalog to see the general arrangement of the brackets and clamps. However, it would be very, very, helpful if someone were kind enough to direct me to a picture of (or post a picture of) the installed steering components on a Mk4 Spitfire. As it is, I'm not even really sure how far up or down the column the switch is supposed to be... and there must be a plastic cover for the lock that I am missing. It can't be exactly what it looks like right now!
Thanks in advance for any advice, dimensions, or pictures that you can share.
dklawson
dklawson
Well, after spending some time looking at the catalog diagrams, the diagrams in Bentley, and the pile of parts left by the previous owner, I may have figured out the general arrangement. I still need help with two things.
1) There is a welded assembly of two parallel tubes bent into a dog-leg shape. The ends are flattened to bolt against the steering column mounting clamp blocks. In addition to the dog-leg shape, one end is offset in height. Can someone explain to me if this part goes above or below the column and generally "which end is up"?
2) I do appear to be missing a plastic shroud that is supposed to surround the ignition lock. From Bentley it looks like this decorative shroud determines where the ignition lock should be on the column. If someone can describe or photograph the ignition key shroud this would be very helpful. Though I'll be asking a friend if he has an extra one... it looks like I am going to have to search for a lock shroud.
Thank you in advance.
guzzul
Doug - are you referring to item 13 in the attached?
dklawson
dklawson
Hi Ross, yes I'm trying to understand how #13 fits up against the brackets. I know it looks like it's below the column with the "dog legs" pointed right and up, but it doesn't seem to fit very well that way. If that's really the way it's supposed to fit I'll just have to give it another go and see if perhaps I've got one of the other clamping parts on in the wrong position. I'm just looking for a bit of confirmation at this point.
guzzul
My '78 does not have this arrangement otherwise I would go physically check it, but I believe you're on the right track.
The 'dog leg' part of that 'anti-torque tube' should face the bottom of the steering column and the bent legs should go up past the column and mount under the top half of the lower column bracket, and be sandwiched between the two lower bracket felts. The upper mounts should attach below the bottom half of the upper column clamp. If you're having trouble with the length of the anti-torque tube, the upper column clamp is moveable up or down the column. Otherwise it should fit. The socket screws on the top clamp should pass through the anti-torque tube, then into the lower half of the clamp, through the upper half and into the tapped plate on top.
Note that, although it is not shown on the VB parts diagram, in the British Leyland book there are two part numbers for that anti-torque tube. Part number 154977 is the 'standard' part number, but they also specify part number 156559 for Sweden-only. I'm not at all sure what the difference would be, but I just mention it in case you might have the wrong part.
Otherwise, there is only one way that tube should really fit in there and if it doesn't line up maybe the upper or lower brackets are not fit quite right. Again, the upper clamp should slide up or down the column a bit, and the lower clamp is adjustable vertically via the upper clamp bracket.
dklawson
dklawson
Thanks Ross. Weather permitting, I'll get this sorted out this weekend.
dklawson
dklawson
I got the steering column back in place today with much swearing, body contortions, and some carefully selected shims. What confused me from the exploded diagrams and the various bits left by the last owner was I didn't know the relationship of the column mounted ignition switch and the welded bracket. I now understand why people convert to a dash mounted switch. UGH!
It took forever to get the switch in place, the weldment attached... but not too tight... so all the fasteners could be started (and subsequently tightened) without binding. What I thought would be a simple hour job turned into an afternoon. The upshot of today's steering work has spawned my next question/post.
W Spitfire Spitfire 1500 Steering Column Triumph 3
B Spitfire 1973 Spitfire steering column ground Triumph 1
pipercollins Spitfire Spitfire Steering Column Movement Triumph 6
P Spitfire Adjustable Steering Column Spitfire Triumph 0
T General TR Spitfire/ Herald Suspension & Steering Triumph 13
dklawson Spitfire Spitfire Steering Shaft Coupling Construction Triumph 9
Michael Oritt Post-War Other Triumph Herald/Spitfire steering rack Triumph 7
TR4 Spitfire Identify this steering wheel, possibly Spitfire? Triumph 10
B Spitfire Spitfire Mk1 Steering Rack - can there be stops? Triumph 0
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
